    Problem with Copy along path plugin
    1 Posts 1 Posters 392 Views 1 Watching
    • J
      jackalvn
      Hi all!
      While playing with Copy along path plugin, I met a problem:
      The plugin runs an array of component along a path starting with one end of the path.
      This end is understood as the start of the path when I draw it.
      In case I want the array runs in the opposite direction, I need to change the start of the path.
      How could I do this without drawing the path again?
      Thanks for your attention!
