    Threads Needed, Waits Wanted
    7 Posts 4 Posters 690 Views 4 Watching
      MartinRinehart
      I've added an extra parameter to my SketchTalk m command. It's the number of seconds over which the move should be done. This floats a component instance referred to by b up 20 units in 5 seconds:
      m b, [0,0,20], 5
      Problem is, this may or may not execute a single frame of the first move:
      m b, [0,0,20] m b, [20,0,0]
      This is the movie function:
      def movie( args ) # animated move
          inst = args[0]
          vec = args[1]
          nsecs = args[2]
          nframes = nsecs * $sketch_talk_fps # $sketch_talk_fps is a float
          frame_vec = [ vec[0]/nframes, vec[1]/nframes, vec[2]/nframes ]
          mover = Mover.new( frame_vec, nframes, inst )
          anim = Sketchup.active_model.active_view.animation = mover
          puts 'main? ' + (Thread.current == Thread.main).to_s()
          until anim.done
              puts 'done? ' + anim.done().to_s()
              Thread.current.sleep( 100 )
      end # of movie()
      Yes, it reports, Thread.current == Thread.main
      No, it reports, anim.done is false.
      It reports this exactly once. I am trying, via the loop at the end of movie() to wait for the animation to finish before going on to the next one. But it seems that the wait loop doesn't do any waiting.
      The @done is set to false in the Mover constructor, reset to true in the Mover's stop() method. The View calls stop() correctly.
      The Ruby code has priority. An infinite loop (no call to sleep) loops infinitely and no animation takes place. Calls to Thread.yield() don't work, either.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        From previous threads on ... threads πŸ˜’ (no pun intended) it appears that threading in SU ruby is a no-go. Unleashes all kinds of demons of other dimensions.
          cjthompson
          Is there any reason something like this wouldn't work?
          now = Time.now
          UI.start_timer(0,true){
            if(Time.now - now > 0.5)
              puts "Test"
              now = Time.now
          • Dan RathbunD Offline
            Dan Rathbun
            Yes.. there's no exit condition to exit from the timer loop (stop_timer).
            And.. since your not using any start delay (the first param is 0,) it's not necessary to use UI.start_timer, just use a normal Ruby loop of some kind, ie: do .. while, etc.
            But CJ your on the right track using Time.now as a test condition.
            I'm not here much anymore.
              @dan rathbun said:
              A normal loop will lock up any other processing. I wonder if a Timer loop allows for other things to process..?
                Dan Rathbun
                How does this topic "jive" with: Re: Timer < 1.0 seconds ?
                http://forums.sketchucation.com/viewtopic.php?f=180&t=26454&start=15#p242163
                Psst, I haven't had time to test that code yet.. Has anyone else?
                  MartinRinehart
                  I had this brilliant idea (that was a total flop). Since the delay works between frames in an animation, why not just grab that one?
                  Was working well until I moved the puts Time.now() - start out of the animation code and into the mainline:
                  for i in 1..10 do waiter(500); puts Time.now() - start end
                  That said something like 0.03, 0.06, ... So I moved a call to a continue() method into the animation in response to stop(). BugSplat.
                  I think I know how to at least solve the starter problem. The animated "move" commmand stacks move specs that are then run in an animation. Kludgy? Yup. PITA? Yup. But it should actually work.
