    Chair modelling help
    3 Posts 3 Posters 377 Views 3 Watching
    • R
      radgabaliyev
      Hello. I want to model a chair, and dont know how, how i can extrude the legs that are not in 90 degrees?
      in the picture I attach you can see what chairs should i model. Please help me.
      • GaieusG
        Can you re-attach that picture?
        • Jean LemireJ
          Jean Lemire
          Hi Radgabaliyev, hi folks.
          You can model your leg at 90°. This shall simplify your life considerably.
          Then, when completed, rotate the leg to the required angle.
          If the top or bottom end or both needs to be horizontal, use cutting planes (circle, rectangles, whatever) correctly positionned and then intersect that plane with the leg. Delete unwanted geometry.
          Just ideas.
