    Web Dialog bug?
    5 Posts 4 Posters 466 Views 4 Watching
      Brett McAllister
      Hi there
      Currently I am creating some web dialogs and having some real issues with stability.
      For no reason at all the dialog will just shut and what ever I have been working on will be lost.
      Have any of you guys had this issue or is it just me?
      Any help would be appreciated. I am using Sketchup 7
      Cheers
      Brett
        tomasz
        One have to be careful especially when using a Tool and a Webdialog (and Observers).
        I think you crash SU because your tool closes a WebDialog already closed or something similar. It can also be caused by creating several instances of a same WebDialog without closing former.
        In a thread called Tool <> WebDialog <> Observers relationship I have started to build a 'proper' way of creating a Tool, WebDialog and an Observer. It is far from perfect. I am still learning how to make it error-proof.
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          Jim
          Brett,
          It sounds like Ruby is garbage collecting the dialog - I've had this happen. If you are using a local variable to reference the dialog and the variable goes out of scope, it will be GC'd.
          # This dlg variable will get GC'd sooner or later and the
          # dialog may go away.
          def create_dialog
              dlg = WebDialog.new(...)
              dlg.show
          One common solution is to use a module to create a namespace (a scope,) and use a class variable to reference the dialog.
            Brett McAllister
            Thanks for the replies.
            The only ruby code I am using is just to load the dialog to test it so there is no namespacing etc.
            Sounds like that will solve the problem,so I will keep that in mind as I get further along.
            Cheers
            Brett
              MartinRinehart
              Cheers
              Brett
              Failure to include two parameters in the code block of an action callback is a crime punishable by BugSplat.
              PC or Mac?
              Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
