    [Plugin] Delete Interior Faces
    6 Posts 5 Posters 12.2k Views 5 Watching
    • K Offline
      kyyu
      This is a plugin, I've been trying to figure out for a few months. Just got the "Automatic Sketchup" book last week, which helped alot. Like the name saids, deletes all interior faces. Just select and use right click context menu. Look in submenu [kyyu].
      Copyright(C) 2010, kyyu
      All Rights Reserved
      Name: Delete Interior Faces
      Version: 1.0
      SU Version: 7.0
      Date: 05-04-2010
      Description: This plugin deletes all Interior Faces of a part(s)
      Usage: Select the parts and right click context menu ( [kyyu]/Delete Interior Faces )
      History:
      1.0 (05-04-2010) - first version
      Before
      After
      v 1.0
      sketchup test file
      -Kwok
        Welcome to SCF! And an extra welcome for being a plugin writer. πŸ˜„ πŸ‘
        • K Offline
          kyyu
          Hi Thomas. Thanks for the welcome. It feels good to finally have something to share. πŸ˜„
          -Kwok
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            To delete all interior faces in only 3 steps, try:
            1 - Select all (CTRL-A).
            2 - Press and hold down the SHIFT key to add/subtract to the selection. While still pressing on the SHIFT key, double click anywhere on the face between the holes. All this face including its external perimeter and the perimeters of all the holes will be deselected, leaving selected only the inside faces of all holes.
            3 - Press the delete key.
            Just ideas.
              Magnus123
              Don't seems to work on skp 2016-2017 only one face is erased 😞
                Same result...but you can use the trick by Jean Lemire above! πŸ˜‰
