    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Sun
    7 Posts 3 Posters 774 Views 3 Watching
    • Z Offline
      Zacchia
      Hi you plugin masters!
      I wish to have such a plugin: moving the sun to the center of the view, i mean to the center of the screen, to the view at the moment with just one click πŸ˜‰ If you know Kerkythea i mean the way where the lightsource/sun is loaded when insert one... The reason for this: it is very easy to imagine where the light/shadows comes. Does it allready give something? I use elevation 45 shadows and it is not bad but not excaclty what i am looking for. So if you need ideas to create new plugins this is one...
        Hi Zacchia,
        ThomThom has a "Face Sun" plugin:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=27499
        See how it is easy with it:
          I guess the plugin would not be hard to modify so that the camera is facing the sun in one step but two steps is not too many either.
          • Z Offline
            Zacchia
            Thanks Gaieus
            This one is not bad, i thank you for answering me πŸ˜› What i do not like on this one: when rotate the scene after applying the plugin and set axis new then the scene do not rotate around the blue axis...
            • Z Offline
              Zacchia
              In SU8 there is new function "sonnennorden" (german) With this i can move the shadow 360Β° around like i wish to do
                You can do that in SU6 and 7 - just that you do it from Window > Model Info > Location
                • Z Offline
                  Zacchia
                  Yes but for fast viewing where the shadow falls this new function is fine...
