    Save panel when new SU file
    3 Posts 2 Posters 702 Views 2 Watching
    • K Offline
      kat
      Hey,
      In a script I try to make a new SU file to save in the components folder and draw a text object into. Therefore I first have to know the path of the old SU file in order to be able to open it again after opening, drawing in, saving and closing the new SU component file.
      I do this with an inputpanel so I can save the path the user has chosen, but when I then make a new SU file with
      Sketchup.file_new
      Sketchup automatically asks the user to save the current file and opens a second save panel again.
      def make_skp()
      ss = Sketchup.active_model.selection
      skp = Sketchup.active_model.name # Name of the current SU model
      path1 = Sketchup.active_model.path # Path of the current SU model
      # Settings of the selected text object
      tekstlabel = ss[0]
      v = ss[0].vector
      name = ss[0].text
      l = ss[0].leader_type
      a = ss[0].arrow_type
      p = ss[0].point
      tekstlabel.erase! # Delete the text object
      UI.messagebox "Please save your SU file."
      path2 = UI.savepanel("Save as",path1,skp)
      # Check if path2 ends with skp
      	p = path2.split(".")
      	if p[1] != "skp"
      		path2=path2+".skp"
      Sketchup.active_model.close_active # Close the current SU model
      su = Sketchup.file_new # Make a new SU file for the text object
      path3= File.join($components, "Opbouw", name+".skp")
      su.active_model.save(path3)
      # Make a new text object with the same settings in the new file
      	t = su.active_model.entities.add_text(name,[0,0,0])
      	t.vector = v
      	t.leader_type = l
      	t.arrow_type = a
      	t.display_leader = true
      su.active_model.save(path3) # Save the new SU file
      su.active_model.close_active # Close the new SU file
      # Open the old SU file again
      Sketchup.open_file(path2)
      The code I wrote works perfectly, but does anyone has an idea of how to avoid this second savepanel witch is a little bit annoying to fill in all over again?
        Why not use the save_as method of the component definition?
        http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as
        Going about creating a new model for a component sounds cumbersome.
        • K Offline
          kat
          Thanks, can't see why i didn't think of that...
