    Ruby Help for Components & Layers
    3 Posts 2 Posters 390 Views 2 Watching
    • K Offline
      ktkoh
      I am trying to move a component created in a rb file to a new layer also created by that file. This code moves the enities so they are only visible on the new layer but when I check the Info the component is still on layer0. Is there a way to define the component layer knowing the name? Or is there a way to select the component knowing the name? (As I am able to change the layer of a selected component so I could make that work.)
      model = Sketchup.active_model
      model.start_operation "CreateBox"
      name = "WebTest"
      layerno = "01"
      # Create new layer for Part Assembly
            layers = model.layers
            newname = "A" + layerno + "-" + name
            if layers[newname]
      	 UI.messagebox("Layer \"#{newname}\" exists, exiting.")
      	 return
            layer = layers.add newname
            pb = layer.page_behavior = LAYER_IS_HIDDEN_ON_NEW_PAGES
            model.pages.each { |p| p.set_visibility( layer, false ) }
          entities = model.active_entities
          group = entities.add_group
          entities = group.entities
          pts = []
          pts[0] = [0, 0, 0]
          pts[1] = [10, 0, 0]
          pts[2] = [10, 1, 0]
          pts[3] = [0, 1, 0]
          base = entities.add_face pts
          width = -4if( base.normal.dot(Z_AXIS) < 0 )
          # Now we can do the pushpull
          base.pushpull width
          # Put entities on layer named "newname"
          entities.each{|e|e.layer=newname}
          # Now we are done and we can end the operation
          model.commit_operation
          # If you want the group to be a Component try the following.
          component_instance=group.to_component
          component_instance.definition.name=name
      Keith
        You never set the layer property for your group.
        at where you got this line:
        add:
        group.layer = layer
          And if you want to create components, then you use model.definitions.add "newCompName"
          http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#add
          And then place an instance of the definition. http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_instance
          Instead of making a groups and then converting the group.
