    Line quality
    layout
    2 Posts 2 Posters 1.5k Views 2 Watching
      jonathanb
      I am a novice at Layout 2.1 and am curious as to why i can't get a great line quality when importing a model into layout. Is there any way of getting a crisper line from a model?
      Also could you explain what the raster setting means as opposed to 'vector' or 'hybrid' in the sketch up model toolbar in the tray?
      Thanks,
      Jonathan
      KEP EXHIBIT DETAIL DESIGN.layout
        Hi Jonathan,
        Under File > Document setup > Paper, at the bottom there is the rendering setting. Leave "Edit quality" something lower or medium (for better performance) and set Output quality to high.
        When exporting to raster, High will be 300 dpi, medium 150 dpi and low 96 dpi (I think).
        Raster output is what it says; a simple image output. Vector is vector based but will not export textures just as colours. Hybrid will export edges as vector an textures as raster images.
