    SU Animate arc path problem.
    extensions
    4 Posts 3 Posters 1.1k Views 3 Watching
    • D
      Dik Harrison
      I think I have run into this problem before, but if I resolved it, I no longer have a clue as to what I did. In the attached test file, the animated object should move in an arc (which it does), but at the end of the arc, it moves linearly. The arc path was derived from a circle. What am I doing wrong? Is there a better way to draw an arc path?
      I have SUAnimate 3.1.
      ArcPathTest.skp
      Have fun...
      Dik
      • S
        sepo
        Cadalog, Inc. just confirmed that this is a bug. The bug probably got introduced with 3.1. We are fixing it and will include the fix in 3.2 release. Thanks for reporting it.
        • S
          sepo
          The SU Animate arc problem has been fixed. The latest version of SU Animate (free to existing users) is on http://www.ohyeahcad.com/suanimate/.
          • GaieusG
            Thanks for the heads-up. There was another user with some (probably/maybe) related problem over the Help Forums. I also "updated" the topic there with your info.
