    Vertices and selection
    9 Posts 5 Posters 781 Views 5 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      I am sure someone else has this figured out already: How can I move a vertex with Ruby? The transform! method is not available with a vertex, otherwise this should work:
      vertices[0].transform! transformation
      Also, is it possible to select an object by its ID?
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • mitcorbM Offline
        mitcorb
        Are you speaking in terms of selecting vertices rather than faces or edges? If so, you might note that ThomThom is working on a script with vertices as a selection set.
          I saw thomthom's plugin but what he does is way beyond what I want to do. I just want to address an object (edge, face, vertex) by ID (not by clicking!) and then transform it.
          Cheers,
          Alex
          • scottliningerS Offline
            scottlininger
            Alex,
            You can transform vertices by using Entities.transform_entities method.
            There is no built in way to get at something by id. You could populate a hash yourself, though. Something like...
            entities_by_id = {}
            some_id = nil
            for ent in Sketchup.active_model.entities
              entities_by_id[ent.entityID.to_s] = ent
              some_id = ent.entityID.to_s
            # And then get back to stuff like this
            my_last_ent = entities_by_id[some_id]
            Cheers,
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              As Scott said, Entities.transform_entities, or by Entities.transform_by_vectors.
              Entities.transform_entities is good when you have one transformation you want to apply to all entities.
              Entities.transform_by_vectors is good when you want to transform a set entities each differently.
              For Vertices, Edges and Faces you tell the containing Entities collection to perform the transformation.
              Only Groups and ComponentInstances has .transform! methods which can be used directly on the object.
              You mean entity.entityID ? Or some other form of identification?
              Maybe this could be better answered if you described the scenario you want to solve?
                Thanks Thom and Scott for the suggestions. I'll try it out later today.
                The scenario would be to have a model with nothing selected. The script would then select an entity and apply a transformation based on me giving it some ID. This is easy if I select by type (e.g. "all faces") and apply the transformation on all of them but I am wondering if I can do it with an individual selection by ID.
                Cheers,
                Alex
                  I'm still confused to exactly what this ID is.
                  How are you determining which entity to transform?
                  From a user perspective, what would you do?
                  • Chris FullmerC Offline
                    What kind of "ID" do you mean Alex? Entities have ID's associated with them, but they are not kept from session to session. So if you make a hash of ID's and then save them to reuse, you will have to rebuild it to match your saved list of hashes each time. That is the only way ID's seem like they would really help you. And from what I hear, that adds a LOT of size to the skp file, because you have to tag each entity that you are tracking with your own ID to match back to your database.
                    Chris
                    All my Plugins I've written
                      Thanks for the replies. I'll have to get back to this later, so please don't think I am ignoring you...
                      Cheers,
                      Alex
