    LIGNES BETWEEN PICTURE OF TEXTURE
    5 Posts 2 Posters 290 Views 2 Watching
      sco071
      hI
      I DON T UNDERSTAND WHY WHEN I USE A TEXTURE ON A ROUND I HAVE A LIGNE BETWEEN ALL THE PICTURE OF THE TEXTURE
      THERE IS OF COURSE NO SUCH LIGNE ON THE BORDER OF THE PICTURE
      COULD YOU HELP ME
      THANKS
      sTEEVE
      A VERY FRESH SKETCHUP USER
        Hi Steve (and welcome),
        Could you post a model with this problem (under the text area when you are posting there is the attachment tab).
        (And you left your CapsLock on)
          sco071
          http://img94.imageshack.us/img94/674/probtexture.jpg
            sco071
            Hi Every Body,
            Nobody can telle me where i make a mistake with this texture
            Thank you for answering me
            All the best
            Steeve
            @sco071 said:
            hI
            COULD YOU HELP ME
            THANKS
            sTEEVE
              Hi Steeve,
              What I ca see, this model curves in all 3 dimensions so simply wrapping the texture around will not produce a good result in native SketchUp. As far as I can tell from the images, probably the UV Tools plugin, more exactly its spherical mapping tool could produce some much better results.
              Download the plugin from the very bottom of the first post in the topic I linked above.
