    Help with table legs needed.
    11 Posts 4 Posters 930 Views 4 Watching
    • G Offline
      Gumleguf
      Hi all,
      New to the wonders of Sketchup, but loving it and learning more and more as I go along.
      I'm using Sketchup to make models of furnitures. The models I'm doing are mockups from which the customers approves the furniture, and the model is then also used by the person who is actually building the furniture. So nothing really advanced or hightec stuff here.
      I do however run into some problems with objects that have "special" shapes. At the moment I'm doing a table, and the legs I'd like to show on the model is the "wire-legs" as seen on the Piet Hein Superellipse table:
      http://schiang-living.dk/images/produkter/nT4XWqg1.jpg
      I don't know how to go about building an object with this shape. I have taken a look after a tutorial that could help me along, but was not able to find something (that I could understand, anyway).
      Is someone able to point me in the right direction?
      /G
        Hi G/ and welcome!
        You can draw single lines (or use arcs to draw curved ones) then use the Follow me tool to shape the legs to thin "wires".
        • G Offline
          Gumleguf
          Hi Gaieus,
          Thanks for the welcome.
          I tried your suggestion and drew a single arc. Once I understood that the face must be pendular to the path I was able to start building. I'll put some more effort into it, and get back with more questions (or hopefully a finished leg).
          Follow Me Tool
          Thanks again for the hint! πŸ‘
          /Greg
            Two things to take care of:
            • make sure that any curved path (arc) has a bigger radius than your circle that follows this path (otherwise it will "twist" into itself)
            • When you experience that some faces are not created, the reason will probably be that they are too small (SU won't create faces whose edges are as small as ~1/16" or ~1mm). In such a case, scale your model up by (say) 10 and when finished, scale it back by 0.1
            • ely862meE Offline
              ely862me
              If u divide the circle in 3 and draw an arc and use follow me on it, should be easy .. like this..
              Elisei (sketchupper)
              Come and See EliseiDesign
              • G Offline
                Gumleguf
                Excellent. Thanks. I'll give it a (newbie) shot. πŸ˜‰
                • FrederikF Offline
                  Frederik
                  That wouldn't be the right way of doing it, since the legs on the Piet Hein Superellipse table is four single tubes...
                  I've attached an example of how I would do it...
                  Pretty simple... πŸ˜‰
                  Legs.skp
                  Cheers
                  Kim Frederik
                  • G Offline
                    Gumleguf
                    Hi all,
                    I have made a quick model to try some of your suggestions. It seems to work out ok for a mockup.
                    Piet Hein Superellipse leg
                    Frederik -> Thanks for your model. I believe your version is more true to the original.
                    You have all been very helpful, so thanks a lot for sharing! πŸ˜„
                    /Greg
                    • ely862meE Offline
                      ely862me
                      Didn t saw exactly how they look like..sorry for that.
                      Anyway--seems like u re getting there πŸ˜„ . Great job!
                      • FrederikF Offline
                        Frederik
                        Didn't mean to pick on you, Ely... Sorry if you felt that... 😳
                        Cheers
                        Kim Frederik
                        • ely862meE Offline
                          ely862me
                          Hey..no problem(i didn t felt like that)- i should have watch better .. now i know how they look like.
                          Take care!
