    Pagoda roof
    9 Posts 5 Posters 3.0k Views 5 Watching
      Ronin
      Hi all,
      I try to make a "look like" replica pagoda of the Durping Gompa but cannot success to draw the roof, if someone could explain me step by step how to do it will be great, thanks in advance.
      Original Durping Gompa
      A sketchup look like Durping
      The type of roof i want to add on my two  roof project.
      • numbthumbN Offline
        numbthumb
        Hi,Ronin
        Check out this thread http://forums.sketchucation.com/viewtopic.php?f=15&t=6252
        Hope it helps.
        Comfortably numb...
          Ronin
          Thx your links help a lot i will try and send the pics result in next message.
            Ronin
            Ok i made a design but it appears to have some problem and dont find the way to solve it :
            When i draw the roof some of the roof's segment appear with lots of "extras line" that i didnt apply for !
            Here what is the result in pictures :
            The mysterious line wich appears on the sketch
              Hi Ronin,
              Select the whole roof, right click and "Soften/Smooth edges". A dialog will pop up; move the slider to the right until all the edges disappear.
              Alternatively you can use the Ctrl+Eraser tool to soften individual edges. This only works when you can access those edges (i.e. if they are in a group, double click to edit the group).
                numbthumb
                Maybe you should weld those lines first - check out this neat plugin http://www.smustard.com/script/Weld
                Comfortably numb...
                • K Offline
                  koz786
                  I was designing a mosque i had similar problem. But managed to fix it by select one of the face.
                  -press Q(rotate)
                  -from centre axis along blue axis(z-axis)
                  -press CTRL
                  -rotate and place it on points
                  • times by number side of the shape
                    for e.g octagon x8
                    -press enter
                    done
                    sheyue
                    This is a method from Chinese SketchUpbbs,author is sharwe.
                    http://www.sketchupbbs.com/viewthread.php?tid=6729&extra=page%3D1%26amp;filter%3Ddigest
                      Hi sheyue,
                      That site needs one to be logged in to view whatever you link here from.
