    Stuck with sketchup texturing can someone help?
    3 Posts 3 Posters 332 Views 3 Watching
      Blah11
      I am really bad at texturing but on the other side I am really good at photoshop and the Bamboo pad. Since I basically given up 100% on UV unwrapping I found out another way "10X easier way" BUT unfortunately I cant figure out how to make it work.
      Basically its to paint over the 3d. I cant find the plugin anywhere and I dunno how to make it work in photoshop. IF it were possible I would like to use my bamboo pad but beggars cant be choosers. Please if you can help me it would be greatly appreciated.
      • K Offline
        KXI System
        Do you mean projecting a picture on a curved surface?
        Getting the perfect sig is hard...
        Google it!
        • numbthumbN Offline
          numbthumb
          Hi, Philip,
          I don´t really know what kind of plugin do you have in mind.
          There is a way to set up Photoshop so it can use the tablet input, but I don´t
          know if this applies to mesh painting.
          As far as I can remember, PS CS4 Extended allows import and export of OBJ, U3D, KMZ, Collada and 3DS models import.
          You can edit textures on 3D model in PS CS3.
          Comfortably numb...
