    Maxwell Displacement Part II Solved!
    extensions
    6 Posts 2 Posters 1.7k Views 2 Watching
      Aidus
      Hi all!
      Long time no posts from me πŸ˜„
      Here is another problem:
      http://img710.imageshack.us/img710/1562/errorma.jpg
      Some weird ripples apear on surface when rendering. My guess is that something is wrong with vertex normals. Geometry is made in Sktechup then exported as OBJ added some adjustments in Modo and then imported in Maxwell render.
      Here You can see some of geometry and normals:
      http://img689.imageshack.us/img689/3501/gridm.jpg
      I'm really stuck with this problem 😞
      This is the project (work in progress) where I need that (censored) grass πŸ˜„
      Result:
      Problem was with normals. Maxwell used surface normals and vertex normals and that made those riples. I deleted surface normals in modo and now displacement rendering is correct.
      PS. Remove surface normal map and then freeze geometry.
      CPU: Intel Core i7 Extreme Edition 965
      RAM: OCZ Gold DDR3 1600MHz 12Gb
      Video: Asus Radeon HD4870 X2 2Gb
      Mobo: Asus P6T Deluxe 1366 Intel X58
      • soloS Offline
        solo
        Aidus, firstly I do not use maxwell so I really cannot offer any real solutions...however....
        When you export or in Maxwell have you tried welding vertices?
        http://www.solos-art.com
          Aidus
          And how can I do that? That welding vertices stuff?
          • soloS Offline
            solo
            how do you export to Maxwell?
            If it's .3ds then in the SU export dialogue you can do it, however I assume you have a maxwell exporter that should have this option, what about in Maxwell studio? there must be some sort of geometry tools where you can weld and smooth mesh.
            Any maxwell users out there that can assist?
              Aidus
              Ok Ill try 3ds and then tell You how it's work.
                Aidus
                Thanks Solo for reply!
