    Compute Rotation and Scale from Transform Object
    26 Posts 9 Posters 5.6k Views 9 Watching
      Ruts
      I did delete the rotX/Y/Z methods, that's why I didn't understand where the variable xyz came from and why it could get value = 0/1/2. I do understand how methods with there variables work. Sorry was confused.
      On the other hand, I have been working with the euler_angle method for a while and now that I'm closely getting to a complete script I have noticed this method only partial works (for me?). Does it work for you guys? When I did draw shapes with a given rotation, the method didn't succeed to calculate the right angles for me so I did some research and made some changes. Here's the code I use:
      	def self.rotation(trans)
      		b = [trans.xaxis.to_a, trans.yaxis.to_a, trans.zaxis.to_a]
      		m = b.transpose.flatten!
      		if m[6] != 1 and m[6] != -1
      			ry = -Math.asin(m[6])
      			rx = Math.atan2(m[7]/Math.cos(ry),m[8]/Math.cos(ry))
      			rz = Math.atan2(m[3]/Math.cos(ry),m[0]/Math.cos(ry))
      		else
      			rz = 0
      			phipos = Math.atan2(m[1],m[2])
      			phineg = Math.atan2(-m[1],-m[2])
      			if m[6] == -1
      				ry = Math;;PI/2
      				rx = rz + phipos
      			else
      				ry = -Math;;PI/2
      				rx = -rz + phineg
      	return [rx.radians,ry.radians,rz.radians]
      First I found this document (page 5) that explains the calculations the way you do it. But it seems that you miss little pieces of code to make it complete.
      When I did calculate the angles it yet didn't calculate the right angles. So I did try some things and found out that the angles that were calculated represent the transpose matrix of the rotation that I need. So I fixed this by transposing the rotation matrix before the calculations.
      With these changes this piece of code does calculate the right angles. Did your code work for you?
      • Dan RathbunD Offline
        Dan Rathbun
        You realize that this topic thread is like 4 and 1/2 years old ?
        I'm not here much anymore.
          Ruts
          Yes, I have seen it. That does not mean that people can't come here and look for code that works? That's how I landed here. I was looking for some code that could convert the rotation matrix to euler angles. I found out that this code didn't work for me, so I did correct it and now I share it here just in case people experience the same problem as me. I'm just excited that I finally can contribute a little instead of always asking things!
          Nothing wrong with that, right?
            Dan Rathbun
            @ruts said:
            Yes, I have seen it. ... Nothing wrong with that, right?
            I was referring to your asking questions of original posters, who might not remember, or might not even have been active here for some time.
              Jernej Vidmar
              Hello transformation gurus!
              just to double check the euler_angle(xyz=[]) method ... is the condition:
              if m[6] != 1 and m[6]!= 1
              at the beginning correct? Why double checking the same variable against the same value? Or is it meant to be:
              if m[6] != 1 and m[6]!= -1
              Cheers,
              Jernej
                An olde typo - use 1 for the second test...
                • 2 / 2
