    3d printing / sketchUp to STL file format help needed
    6 Posts 3 Posters 773 Views 3 Watching
      cmh
      Hi-
      I am an architecture student trying to get a sketchUp file to be 3d printable and I am having difficulties.
      I have used CadSpan on my model and can get a STL file to open in SolidWorks as a part but is not able to be saved as an STL file. The 3D printer software is also not recognizing the CadSpan STL file.
      I am seeking advice on workflow path/software from those who have had success 3D printing a model designed in sketchUp-
      Thanks!
      • soloS Offline
        solo
        Got a model you need tested?
        I can give it a go using Deep exploration and you can then evaluate how it works.
        http://www.solos-art.com
          cmh
          http://sketchup.google.com/3dwarehouse/details?mid=265d0ef09f13866957bab142997ef2c2&result=4
          Thanks-
          library 11.3.skp
          • soloS Offline
            solo
            Try this.
            cmh.zip
              cmh
              Thank you!
              I'm on spring break this week from school so I don't have access to the printer until next monday, is "Deep exploration" an STL conversion program you ran on my model? Is there a preferred software to use for going from sketchUp to STL?
              I am the first architecture student at my school to get access to the 3D printer so I am learning as I go...
                Jim
                Here's your model with some notes pointing to things that 3d printing does not like.
                I've been playing around with shapeways recently - they accept collada files so you don't even need to go to a .stl.
                In general, your model needs to be scaled to fit on print bed, be water-tight, and not have any interior faces. And no over-lapping faces.
                Following those rules, I can consistently produce 3d-printable model directly from SketchUp (for shapeways, anyhow.)
                library 11.3[jf].skp
