    Tool <> WebDialog <> Observers relationship
    23 Posts 4 Posters 1.5k Views 4 Watching
      def onCancel(reason,view)
        @web_dialog.close
      Do you need to close the webdialog here? It does not stop the Tool.
      If the tool is a line tool for instance, and the user starts to draw a line:
      Clicks once to set start point - then the tool enters a state where it expects the user to pick another. but if the user hit Escape this event is triggered with reason == 0 - and the tool should then reset itself. But the tool itself is not killed.
        @dlg.set_on_close { puts "Set on close fired." Sketchup.active_model.active_view.remove_observer ProperTool::get_view_observer Sketchup.active_model.select_tool(nil) }
        Regarding Sketchup.active_model.select_tool(nil) - that will activate SU's Select tool. I'd recommend that you instead use Sketchup.active_model.tools's push_tool and pop_tool so that when you deactivate your own tool it return to the previously selected tool (which might very likely not be the Select tool)
          tomasz
          @thomthom said:
          You're missing a puts.
          πŸ‘Š
          >   @web_dialog.close
          > end
          It is just a single stage tool. If an user presses escape I want to close the webdialog and deactivate.the_tool. Invoking @dlg.set_on_close {Sketchup.active_model.active_view.remove_observer ProperTool::get_view_observer; **Sketchup.active_model.select_tool(nil)**} will close the tool... and will trigger @web_dialog.close again. That is why it fires up twice.
          • 2 / 2
