    Texture Problem
    11 Posts 3 Posters 822 Views 3 Watching
    • K
      KXI System
      Wow, I've never thought I'll ever use these part of the forms like this... Oh well I am noobish 😳
      Anyways, when I put a texture on a curved surface it seems... warped:
      Anyone know how to fix this?
      I feel so noobish than my noobish nooba self...
      Getting the perfect sig is hard...
      Google it!
      • GaieusG
        You will need Whaat's UV Tools to correctly position a texture on a (hemi)spherical surface. Note however the at the very top (where there are already triangles only), it will still be distorted a bit.
        • K
          KXI System
          Thanks, and where are they?
          Google it!
          • GaieusG
            http://forums.sketchucation.com/viewtopic.php?f=323&t=10404&hilit=plugin
            • X
              xrok1
              better to use a geodesic sphere from the component library than a normal sphere. it doesn't have the pinching.
              btw, has anyone noticed you can't seem to use project texture inside a group but if you explode the group or explode and regroup you can project on the exact same face?
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
              • X
                xrok1
                oops. 😳 i found this post by TIG in another thread.
                You can't edit a texture that's been applied to a group or component instance - 'en mass', or a textured "surface" when hidden-geometry is 'off'.
                However, you can edit a texture that is applied directly to a face.
                • K
                  KXI System
                  Hey, it seems like as soon as I got the plugin my problem kinda went away:
                  But after I did the instructions:
                  Google it!
                  • X
                    xrok1
                    did you try the geodesic sphere?
                    • K
                      KXI System
                      I tried both, same result.
                      Google it!
                      • X
                        xrok1
                        for some reason after you use uvtools you have to scale your texture way down. ie. if your texture is 2' before try 2" after. 😕
                        • K
                          KXI System
                          I found UV toolkit, and my problem is GONE!
                          Google it!
