    SU integration with cnc bench
    3 Posts 2 Posters 247 Views 2 Watching
      markpyvi
      Has someone made some drawings in SU for later use in cnc bench. Is it reasonable at all use SU drawings after exported into dwg at that case? Or do I have to make my drawing in ACad only?
      Thank you,
      mark
        Jim
        There is a product called the phlatprinter, which is a low-cost cnc foam cutter. They have developed a Sketchup to gcode plug-in that may be useful:
        (www.phlatforum.com)
          markpyvi
          Thanks for reply Jim. As I see, SU is not good for cnc bench documentation.
          mark
