    How to make a "flat" spirale ?
    3 Posts 2 Posters 242 Views 2 Watching
    • L
      LeRogerTroutman
      Hello everyone,
      My problem is not that easy to explain, but easy to understand with a look on my .skp file :
      http://www.megaupload.com/?d=FRWU7ASP
      Basically, I made a I spirale, then drew a rectangle and applied the follow-me tool on it (with the spirale as my path).
      But I want the "rectangle spirale" to be flat, and it is curved, it turns on itself like an apple peel would...
      Any idea about the good method ?
      Many thanks in advance,
      LeRoger
        you can use 1001 bits !
        free as using like shareware
        or some Extrude Edges tools by TIG
        or the plug "Followme and keep"
        • L
          LeRogerTroutman
          Merci beaucoup Pilou,
          That helps a lot πŸ˜„
          A+ !
          LeRoger
