    Multiple scene renders
    5 Posts 3 Posters 328 Views 3 Watching
    • FlatchoumF Offline
      Flatchoum
      Hey there! Is there a way to make multiple scene renders, only using SU and no plugins?
      I've tryed with "export animation", but it also creates several transition scenes, which seriously increases the time of rendering. Tips welcome, Thanks πŸ’š
      • tridemT Offline
        tridem
        you can disable the scene transition in the animation settings (model info window) πŸ˜‰
          Set the scene transition to (say) 1 second, scene delay to 0 and export with 1 frame per second settings under the animation options. Note however that animation export can only have 4:3 or 16:9 resolution so you may not get exactly what you can see on your screen / in your SU window but cropped a bit unless you set your SU viewport to exactly these resolutions (which is kind of hard without messing up the toolbars on a PC but you may have better luck with a Mac).
            Flatchoum
            Thanks guys, I'll save a lot of time now! πŸ˜„
              Flatchoum
              Just an other question directly linked to the topic: in the "animation export options", on mac, I never could set the frame rate under 5 frames per second, which creates me a lot of useless pictures. Whatever format I'd choose, I never could access the "expert mode", which icon keeps white. I guess this "expert mode" would allow me to select the 1 fps rate, but how to get there?
