    Overview map
    6 Posts 3 Posters 1.2k Views 3 Watching
      tspco
      I was just doing a walk through of one of one of my models, once in a while I run into walls, simply because I did not know how close I was. Is there a plugin to trick to provide an overview map that sits as a inset window somewhere?
      Something that would indicate XY position as well as first floor, second floor, or basement would work great!
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        That would be pretty slick for walk throughs, wouldn't it?
          tspco
          Yepper If the technology worked back in the super Nintendo days, I don 't see why it couldn't work here with the technology we have these days.
          Of course I am not a programmer, and don't even know where to start, not a clue.
          With all the brains here on this forum I am sure somebody will accept the challenge.
          • Chris FullmerC Offline
            I really like the idea of this, btw. I think it should all be possible. The hardest part would be figuring out exactly what themap should draw, and also I think it would require re-writing the navigation tools. But I think it might all be do-able. Rather interesting idea.
            Chris
            All my Plugins I've written
              Chris, it could be useful even if you aren't doing a walk through. I sometimes work on complex models with the camera positioned inside a component. I also demonstrate this to others. I manage with it just fine but sometimes others have a difficult time envisioning what I'm showing them. It would be kind of nice to have a map in a corner showing what it going on.
              Suppose the process included something like a section plane set at a user-determined height above the ground plane. The user would activate the plugin and enter the height. The plugin would create a section plane and perhaps get the edges like TIGs Section Cut Faces and use that for the map. You'd probably need a way to determine how much of the map is displayed as in how far do you zoom in on the map and so on.
              Could it be in a window of its own? Then would could put it off to the side of their SketchUp window or put it on a second monitor if the have it or whatever.
              All easy to ask for since I haven't a clue how to do it. πŸ˜„
                tspco
                A simple section slice would be fine, you don't need any detail just simple 2D outlines. One might be able to activate a plan view that sits in a corner or it could be in a separate window. Or make where and how the map shows up user selectable. The data is already there in the drawing, but how to tap it?
