    Sketchup.find_support_file
    12 Posts 4 Posters 1.7k Views 4 Watching
      tomasz
      Hi all,
      Is there a proper way of using Sketchup.find_support_file that always return correct value on different systems?
      I have reports from users that Sketchup.find_support_file "plugins" returns nil although the folder exists. Also Sketchup.find_support_file "" in some cases fails.
      Is there one reliable way to find out the Plugins folder location?
      Tomasz
        tomasz
        Driven has suggested in this thread that Sketchup.get_resource_path("") gives constant results.
        It returns the resources path though.
          tomasz
          Sketchup.find_support_file("", "Plugins/")
          nil
          Sketchup.find_support_file("", "")
          nil
          Sketchup.find_support_file("")
          nil
          /Library/Application Support/Google SketchUp 6/SketchUp/plugins
          It is a report from SU6 user on MAC.
          • Dan RathbunD Offline
            Dan Rathbun
            (1) Only use double-quoted Strings if your:
            • using Regular Expressions (ie: "\n")* doing #{strVar} replacement
              (2) You'll have fewer problems with the interpreter if you get in the habit of putting ( ) around parameters whenever possible, and with NO space between the method name and the (.
            To find the Sketchup folder(directory) try:
            File.dirname(Sketchup.find_support_file('sketchup.exe'))
            Plugins folder, is empty when SU is first installed, so can't test for a file, but, you can append 'plugins' to the above, using File.join which uses File::SEPARATOR between arguments:
            File.join(File.dirname(Sketchup.find_support_file('sketchup.exe')),'plugins')
            Note: Sketchup.find_support_files (plural) on PC returns escaped backslash pathnames, and sometimes returns arrays of pathnames. It's a pain in the butt.
            I'm not here much anymore.
              Jim
              Mac use .exe?
              How about using $LOAD_PATH[0]? Is it reliable?
                Dan Rathbun
                @jim said:
                Mac use .exe?
                Well.. the point I need to make is.. That Sketchup.find_support_file works best if it has a file to find. In the old days we could not give directories names with .extensions, so we could find dirs with '*.' wildcard. That's not true anymore with 32-bit filesystems.
                He can put a string reference into the method call, and set the reference using a platform conditional statement; sketchup.exe for PC, and whatever it is for Mac.
                Not if the user has moved their paths around.
                However.. hmmm... you could always iterate the $LOAD_PATH array, check each element if it includes 'plugins'
                ` target=''
                $LOAD_PATH.each {|e| target=e.dup if e.downcase.include?('plugins')}
                if (not target.empty?) and File.basename(target).downcase=='plugins'
                Plugins target path is good!
                end`
                EDIT: put ( ) around not target.empty? just in case...
                  tomasz
                  I do have () without spaces in most cases πŸ˜„
                  @dan rathbun said:
                  ` target=''
                  end`
                  It looks like a good solution.
                    MartinRinehart
                    @dan rathbun said:
                    $LOAD_PATH.each {|e| target= ...
                    May I cast one vote for the for ... in ... loop? I adopted it for my tutorial as I was writing for programmers and programming newbies. Then I read that it was indeed faster. And as a long-time, big-time fan of readable code, whatever.each {|x| ... wins no prizes.
                    for path in $LOAD_PATH do ... end
                    Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                      MartinRinehart
                      Hi all,
                      On a PC (where it doesn't matter) the folder is "Plugins". Is the issue simply capitalization?
                      I direct users to find their Plugins folder via Sketchup.find_support_file "Plugins" in the Ruby Console. Zero problems reported.
                        Jim
                        A for-loop is not a drop-in replacement for .each.
                        Variables created in a for loop which you might assume have loop scope are actually visible outside the loop when the loop terminates.
                        Variable created in the .each loop behave as local to the loop, as expected.
                        At least on Ruby version 1.8. I don't know what Matz decided the behavior will be on Ruby 1.9.
                          MartinRinehart
                          Thanks!
                          Ruby never ceases to amaze me.
                            Dan Rathbun
                            Actually Martin.. that example was quick and dirty.
                            It CAN be cleaned up. I was thinking it would be better to break out of the iteration when the proper match was found, rather then keep iterating, though how many paths do most people have in their $: anyway?
                            You'd likely run a method and set a constant (perhaps Integer index into $LOAD_PATH) and then use that reference from then onward. So it should be a one time, startup type thangy...
                            One thing I do is actually put set ENV['SUpath']
