    Pushpull scripting. need HELP plz
    7 Posts 4 Posters 470 Views 4 Watching
    • W Offline
      walid
      hello folks, i need ur help plz
      i was trying to script the pushpull command on sketchup ruby, just immitating the tutorial ( http://www.youtube.com/watch?v=Aq1YEaI2XlA&feature=related ) but unfortunately it didnt work, so i guess ther is a step missing or something going wrong...if u can help it ll be soooo cooool,,,
      thanxxxx
      • Chris FullmerC Offline
        Well, its hard to say if your doing something wrong, without seeing anything you've done πŸ˜„
        But I will say that I'm pretty sure that the video is accurate, as it is written and tested in real time in the video - no Hollywood magic pushpulling the faces or anything.
        So why not post a snippet of your code you are working on we'll see how it looks!
        Chris
        All my Plugins I've written
          loudghirim
          hey i m walid s friend
          wr r working together on this project
          and here is the code we tried to enter yesterday
          the basic of our work is to find out how to make a plugin that digs a cube randomly into different multi geometrial shapes with different sizes and so on...
          thank uuuu
          model = Sketchup.active_model
          sel = model.selection
          model.start_operation "mult. pushpull"
          faces = []
          sel.each do |e|
          faces << e if e.is_a? sketchup;;face
          faces.each do |face|
          face.pushpull [ 100 ]
          model.commit_operation
            NO
            face.pushpull(100)
            or even
            face.pushpull 100
            YES
            [] encloses an 'array' - e.g. a 'list' of things like [0,0,1] - the three points x,y,z
            () or <space> simply separate the arguments from the method...
            pushpull takes a distance not an array
            Here you are pushpulling every face 100 units (inches) in the direction of the face's normal (front face)
            To use other units use a suffix like 100.mm for millimeters
            • W Offline
              walid
              hi TIG i have tried the script in the way u told me 2 but no result..
              i hav noticed that on the u tube tutorial the command was EXECUTE
              on my sketchup it is EVALUATE so does that mak difference ?
              if yes ... how can i download the execute command...
              thanx
                Hi guys, the " execute" versus " evaluate" difference is nothing. It is just a different version of the same tool. They work exactly the same.
                Fix what TIG suggested and then fix this line:
                faces << e if e.is_a? sketchup::face
                the word sketchup is a class and needs to be capitalized, and so should the word face (I think). So it should read like this:
                faces << e if e.is_a? Sketchup::Face
                Try changing that too and see if it works. Ruby is case very sensitive! πŸ˜„
                Chris
                PS Sorry I have been slow to respond here, and I just got your PM also. My computer broke and I have been without internet at home for a few days. But all hard drives are replaced, new motherboard in, new RAID card up and running and I think I might have a useable computer again. Good luck!
                  OK, just got Sketchup and the web console installed on my system so I could test this out. Sure enough, making TIG's changes, plus the ones I showed above, and it all works. This is the final code:
                  faces = []
                  sel.each do |e|
                  faces << e if e.is_a? Sketchup;;Face
                  face.pushpull 100
                  There you go! Let me know how the other tutorials go also!,
                  Chris
