    Floorplans
    12 Posts 7 Posters 1.1k Views 7 Watching
      miller5573
      I was told that sketchup could be used to generate two dimensional floor plans. My limited review of Sketchup to this point does not seem to support that feedback. I am also curious about the ability to click and drag such things into a floor plan such as furniture and appliances.
        Hi Richard,
        Why would SU not be able to create 2D floorplans?
        Also, although most "already made" furniture and stuff freely available are 3D, surely using 2D objects would be easy, too. For another forum topic, I made this (very simple) 2D model:
        http://sketchup.google.com/3dwarehouse/details?mid=adf669de3de3974d5c8c071f2cab4fc6
        If you download it, you can see that for instance moving that 2D loo around is pretty easy with the tool.
          miller5573
          Thanks for the reply. I tried a free trial download of Smartdraw and had a floorplan in no time. It just isn't very intuitive in Sketchup. At least not for me??
            Well, one definitely has to invest a bit of time to learn SU and of course, its strength is not 2D but 3D so if there is a better app for drawing simple 2D floorplans, of course, use that instead. (I have never used Smartdraw)
            • soloS Offline
              solo
              I recommend this, not cheap but friggin awesome.
              Chief Architect | Architectural Home Design Software
              Professional home design software for residential home design, interior design, and remodeling.
              (www.chiefarchitect.com)
              http://www.solos-art.com
                d12dozr
                I've used SU for basic 2D plans...it works fine, but gets messy when adding 3D models to 2D plans.
                For best results in drawing 2D plans, set your camera to parallel projection, top view and draw the plans zooming and panning as necessary, but without orbiting at all. Tig's 2D toolset may help you as well.
                http://goo.gl/f7ooYh
                • honoluludesktopH Offline
                  honoluludesktop
                  Richard, took a quick look at Smartdrw. It is a diagramming tool, completely different from Sketchup which is 3d modeling. IMO, if all you need are 2d plan diagrams, SU may not be the product for you.
                    honoluludesktop
                    Free from Autodesk, Dragonfly
                    • X Offline
                      xrok1
                      that's pretty awsome, what formats can you save to? is the saved file 2D or 3D?
                      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        honoluludesktop
                        "Supported Applications
                        If you export your floor plan from Project Dragonfly to a drawing, the DWG is compatible with AutoCAD 2007 and higher. In the event that you need an earlier version of the drawing, you may download the free Autodesk DWG TrueView and and use the DWG TrueConvert functionality to convert the drawing."
                          SU can import 2007 type files so that should be all right.
                          • Jean LemireJ Offline
                            Jean Lemire
                            Hi folks.
                            See this SU file for ideas.
                            Floor plan.skp
