    Tube that gets wider. How to do this
    10 Posts 3 Posters 573 Views 3 Watching
      bibihest
      Im trying to make a kind of tube around a window on a model. Normally I would use followme, but this tube gets wider when I go around. Are there any speciel trick to make it follow the lines around?
      You can see what I mean in the attachment. The arcs I have made are just to show how its supposed to be.
      • numbthumbN Offline
        numbthumb
        A tube that gets wider could be made with a little help from plugins like this one: http://forums.sketchucation.com/viewtopic.php?f=323&t=21658&st=0&sk=t&sd=a&hilit=2+faces+path
        Comfortably numb...
          bibihest
          Thank you, I will give it a try and see if I can make it work.
            numbthumb
            I am pretty sure there are many other ways to accomplish that, 2 faces+path was just the the first thing that came to my mind.
            If it helps, that´s good.
            Comfortably numb...
              bibihest
              I have been trying to make it work now, but it only makes some weird faces that are not even close.
              And if I do it in sections, one side doesn't fit.
              Any other tips what I can try? 😄
                numbthumb
                Extrusion tools by TIG ?
                http://forums.sketchucation.com/viewtopic.php?f=323&t=26029&p=226673&hilit=extrude+tools#p226673
                Comfortably numb...
                • U Offline
                  Ultimatez 32
                  no need for plugins... 😄
                  Tutorial creating a wider curve.skp
                  Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                    numbthumb
                    Hehe... that´s a neat solution indeed.
                    And a much closer to what he actually needs - and that is definitely not a kind of tube that I had in mind.
                    Comfortably numb...
                      bibihest
                      Thx for your help. I actually did it the manual way with the curves, but man it took alot of time. It wasn't enough to do it with only a couple of curves, there where many 😄
                      I might have done something wrong because it took me over an hours just to fill the gaps and make it end correctly at the bottom. Will give it a try again.
                      Btw the second plugin from numbthumb actually worked well, but it can't do all of it.
                      Thanks guys and have a great weekend!
                        numbthumb
                        Well, hand-stitching indeed takes a looot of time. However, Extrusion tools by TIG is worth having in any case - an entire suite that makes a life easier. Something in there will suit your needs, for sure.
                        Hope you have a nice weekend too!
                        Comfortably numb...
