    Trouble triggering javascript event from sketchup
    14 Posts 4 Posters 1.4k Views 4 Watching
    • C
      cjthompson
      I am trying to create a dynamic web page through javascript. Everything is working except for the "onclick" event for buttons.
      here is an example of what I'm doing:
      class WebTest
      	@@webDialog = UI;;WebDialog.new("This is a test",true,"Test",250,250,250,250,true)
      	html ="
      		<html>
      		<head>
      			<script>
      			function addButton()
      				body = document.body;
      				button = document.createElement('input');
      				button.type = 'button';
      				button.value = 'Click Me';
      				var message = 'I am working';
      				button.onclick = 'alert(message);';
      				button.id = 'btn1';
      				body.appendChild(button);
      			</script>
      		</head>
      		<body>
      		</body>
      		</html>"
      	@@webDialog.set_html(html)
      	def initialize
      		@@webDialog.show
      	def self.addButton
      		@@webDialog.execute_script("addButton()")
      to test it, copy and paste the following code into an .rb, and type WebTest.new, then WebTest.addButton into the console.
      It doesn't work in the sketchup webdialog, but when I copy and paste the same code into a regular browser, it does:
      javascript&#058;body = document.getElementsByTagName('body')[0];button = document.createElement('input');button.setAttribute('type','button');button.setAttribute('id','btn1');button.setAttribute('value','Click Me');var message = 'I am working';button.setAttribute('onclick','alert(message)');body.appendChild(button);
      does anyone have any ideas?
      • M
        MartinRinehart
        Some random notes. I bet one of these (no idea which!) fixes the issue.
        1. "document.body" works. No need to look it up.
        2. "setAttribute" has issues. Easier to say "button.id = 'btn1';"
        3. The WebDialog parameters are wrong in the doc. Never tried to use just one. Try (title, scrollable, registryKey, width, height, left, top, resizable). (Set scrollable true. It will always be true on a PC, regardless of this param's value.)
        4. There are timing issues calling execute_script. Put a button in a minimal WD. Click the button to call a Ruby action_callback. execute_script() in the action_callback. (I named this The Bug from Hell. It took me nearly a week to find this out. If you execute_script() before your page is correctly formed, it won't work and you'll get no error. Ugh.)
        5. Style points: This might all be more readable laid out as a Ruby multiline string:
          html = <<eos
        <html> <body>
        <script type='text/javascript'>
        function make_button() {
        button.attr = value;
        button.other_attr = other_value;
        document.body.appendChild( button )
        </script> </body> </html>
        eos
        @@webDialog.set_html( html )
        Come to think of it, I'm betting on #4.
        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        • C
          cjthompson
          I've edited the top post to reflect the changes you suggested.
          It is showing the exact same behaviour, it adds the button properly, but doesn't trigger.
          • thomthomT
            You are assigning a string to the event.
            button.onclick = function() { alert(message); };
            Maybe you can skip the function wrapper when you only do one method call - can't remember right now.
            button.onclick = alert(message);
            • thomthomT
              hmm... turns out that the string thing is a legacy way of doing it.
              I think that you need to append the element and then attach events.
              • T
                todd burch
                Yes. This works on a Mac: (Didn't test on IE)
                class WebTest < UI;;WebDialog
                	def initialize
                		super("This is a test",true,"Test",250,250,250,250,true) ;
                		html =<<HTML
                <html>
                <head>
                <script>
                function addButton() {
                	alert('hi there');
                	var body = document.body;
                	var button = document.createElement('input');
                	button.id = 'btn1';
                	button.addEventListener("click", function() { alert(message);} , true ) ;
                </script>
                </head>
                <body>
                Yo
                </body>
                </html>
                HTML
                		set_html(html)
                		def add_button
                			execute_script("addButton();") ;
                		end ;
                And, in the Ruby Console:
                > load 'myscripts/webtest.rb'
                true
                > w = WebTest.new
                #<WebTest;0x1d545b24>
                > w.show
                true
                > w.add_button
                true
                • M
                  MartinRinehart
                  Well, that sure is easier to read. To make it work, try my fourth suggestion. Have preliminary JS put up a big button that says "Start!" or whatever. That button's onclick() calls an action_callback in the Ruby. The action_callback can safely execute_script().
                  Another thing I see is the onclick() timing. The click will happen sometime after addButton() has run to completion. message will no longer exist. Move var message = ... outside the function. (No, you really don't have to worry about polluting the global namespace in a WebDialog.)
                  Pay attention to thomthom's remarks re attaching code to the event handler.
                  • C
                    cjthompson
                    For some reason, the alert box is popping up automatically, without adding the button.
                    However, this did work for me:
                    Yeah, I'm not the best keeping up with standards. 😳
                    Anyways, I think that will do it for me. Thanks everyone for the replies.
                    • T
                      todd burch
                      Is the alert box that is popping up this one?
                      alert('hi there');
                      • C
                        cjthompson
                        ah, I completely missed that. Yes it is.
                        I'm getting an error "Object doesn't support this property or method." on this line:
                        Is anyone else with IE getting this?
                        • thomthomT
                          what IE do you got? thing IE might have its own way to attach events...
                          http://www.quirksmode.org/js/introevents.html
                          • M
                            MartinRinehart
                            http://www.quirksmode.org/js/events_advanced.html
                            ppk's conclusion: don't use addEventListener if you need to support MSIE.
                            • T
                              todd burch
                              Like I said, not tested on IE. If the browser does not respond to button.addEventListener, use button.attachEvent.
                              https://developer.mozilla.org/en/DOM/element.addEventListener
                              (By the way, I spent > 2 hours on this last night)
                              • thomthomT
                                button.attachEvent.
                                Yes -that jogged my memory - attachEvent was the IE way. (imagined that later IE (IE7 or IE8) used addEventListener as it's part of the DOM standard. But maybe I was wrong. ...or maybe it depends on the doctype....
