    Multiple views ---> single view
    4 Posts 2 Posters 1.1k Views 2 Watching
    • D
      dsarchs
      Is anyone aware of a plugin that would create multiple scenes/views that would piece together to form a much larger single image?
      I need to do a larger rendering (using Kerkythea) than my computer can handle and thought I remembered hearing about something like the above a while ago. I've tried multiple images with slight camera rolling (like you would do for a panorama with a real camera) but stitching these together is always a little imperfect and it seems like a computer rendering should be able to do better.
      Can anyone think of a solution or plugin that would work?
      Knowledge is a polite word for dead but not buried imagination.
      -e.e.cummings
      • R
        remus
        You could give this a go: http://forums.sketchucation.com/viewtopic.php?f=18&t=26527
        • D
          dsarchs
          Thanks, that technique seems exactly what I need.
          If anyone else is interested in, Tomasz's Bring My View Back plugin seems made for this, allowing you to create a grid on the screen so you know where to make each frame.
          http://www.tomaszmarek.eu/sketchup_1.html
          -e.e.cummings
          • D
            dsarchs
            Actually, I just found another problem. When the SketchUP scenes are imported into Kerkythea, every camera is identical. I assume this is a problem with importing axonometric views -- does anyone know if there is a work-around for this?
            -e.e.cummings
