    Smoove Shape
    3 Posts 2 Posters 928 Views 2 Watching
    • S
      sez
      hello all,
      i need a tool which acts exactly the same as smoove tool with sandbox, but can be configurable as elliptic or free form or etc. as far as i know; smoove would only be radiant. because it does not give the exact shape i need on my model by trying smoove with different radiuses by multiple touches ton the surface..
      is there anything like that? or any configuration i could do? any plugin etc?
      or any suggestion on usage?
      please help me.. since i am a bit better than a newbie, there may be something i missed 😲
      thanks.
      • thomthomT
        Make your selection of Faces and Edges before activating the Smoove tool, then you can use irregular shape.
        I am currently working on a Vertex Editing plugin with soft selection - but it's still a bit to go before it's done.
        • S
          sez
          yes but when i select a part of the surface, it takes all the surface with that yellow dots, so it takes all points up πŸ˜•
          your plugin will be a nice one i think, may the force be with you! πŸ˜„
