    Dimensioning Viewports?
    layout
    2 Posts 1 Posters 989 Views 1 Watching
    • E Offline
      Eric_J
      Does anyone know if there a way to accurately size the viewports? The information bar at the bottom says, "Type values for precise manipulation," when I type in dimensions, it returns, "Invalid string." Sometimes it will let me enter a scale value, but never a dimension...
      What's the deal on this? I'm using Layout 2.1.5803 .....
      TIA
      EJE
      • E Offline
        Eric_J
        OK, I got it.
        It seems to work in relation to the handle that was just dragged. So if you pull a handle on an edge, you can only enter one value, for either the width or height. In order to enter horizontal and vertical dimensions, you have to drag from the corner first.
        Not obvious, but it does make sense.
        Thanks EJE for the fast reply....
        EJE
