    SketchUp transitions. Get more dynamic
    2 Posts 2 Posters 287 Views 2 Watching
    • W Offline
      wwoopster
      I am supposed to initiate a structural dynamics process within the physical model of transformations of Google SketchUp models and objects. So it becomes subjective from rugular model into the physical transformation and bakward transitions.
      Dynamic models within the animation process is what I want to have with Google Sketchup! More physical dynamics in SketchUp models and components. There could be applied some transitions model of the particles pixelization process into the atomic physical model based on the spring rigidity particles connection.
      Particular that means a programming transitions of Sketchup models into the physical particles model during the interaction with its own dynamics of SketchUp components within SketchUp animation plugin, for example. Particular plugin activates during the animation and starts with interaction process of components and the backward transitions returns a regular SketchUp model or component with the resulting physical interaction transformations. Pixelization model into the atoms with rigid spring connectors means a transition of the rugular SketchUp model into the pixels and subpixel physical spring connectors with rigidity properties during interaction of the animated objects. In the backward it returns a resulting SketchUp model with physical transformations. The whole add-on structure of the transition process becomes dynamic too because of the models representation change from the regular into the physical and backward.
      • K Offline
        KXI System
        English please πŸ˜• (see signature below)
        Getting the perfect sig is hard...
        Google it!
