    [REQ] Material to Layer
    4 Posts 2 Posters 628 Views 2 Watching
    • bagateloB Offline
      bagatelo
      Does exist some plugin to make possible to set a material for a whole Layer?
      The vray has that resource, but this doesn't work when the object is inside of another object, this needs to be in the root of the outliner.
      • bagateloB Offline
        bagatelo
        The one that I think is that the Material should fill out all inside of the objects that still don't have material of that Layer. In other words, to fill out spaces emptiness in that layer.
        • Didier BurD Offline
          Didier Bur
          I think my layers/materials script can help.
          I've attached the scriptbecause the Ruby Depot is actually down.
          Regards,
          Put the RB in Plugins folder,short PDF doc included in the Zip.
          DB
          • bagateloB Offline
            bagatelo
            I already knew that script. But the one that I need was something like that:
            Imagine you to create a component with several subgroups. For each one of those subgroups you put in a different Layer. You create other components. And each one of those components has several subgroups, each one of them in different layers, but they are layers in common with other components. Each one of those objects is totally without material. Then now, you want to put several materials in several layers. The plugin render Vray have that capacity, but doesn't work with subojects, this work just with objects that are in the root of the outliner.
            Thanks for your answer.
