    Hello to everyone
    7 Posts 3 Posters 451 Views 3 Watching
    • A
      ALWX65
      Hello to everyone! I am new here and to SU and I am relly starting to like this program. I do have a question though, I made a simple building with four walls that I made 8 inches thick to resemble a cynder block wall. I had to cut the door myself because of the wall style. I would like to change their location but cant seem to make the wall solid again. Any ideas or do I just hve to start from scratch again? Thanks to everyone that helps.
      ALW
      • A
        ALWX65
        I have no idea why that double posted ?????
        ALW
        • D
          d12dozr
          It sounds like you just need to trace over one of the edges of the door to create that face again, then just delete the old edges.
          http://goo.gl/f7ooYh
          • D
            dylan
            Hi Alan and welcome to SCF.
            I have added a very quick and dirty video explaining a few simple methods of achieving what you want.
            [flash=500,405:35pdzztm]http://vimeo.com/moogaloop.swf?clip_id=9615474&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=9615474&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/9615474">Change Door Location</a> from <a href="http://vimeo.com/user3222214">Dylan Morton</a> on <a href="http://vimeo.com">Vimeo</a>.</p>[/flash:35pdzztm]
            http://dmdarchitecture.co.uk/
            • A
              ALWX65
              Dylan, that was exactly what I was looking for! Thank you so much! I do have another question if I may ... What I am building, or playing with, is a garage that is pretty standard. I built the lower level with the door openings which looks like what you showed in your video, but topped it with a 1 foot thick roof. That will be the thickness of some gluelam beams to support the second floor loft. Here is my question, I accidently moved that one foot tall section, I made it a component, now I cant seem to place it back on top of the walls exactly where it was. Is there a way to set it back down exactly even with the walls or start from scratch. Im getting really fast at making new walls HAHAHAHA I guess its the only real way to learn repitition. Anyway and help on this ???
              ALW
              • D
                dylan
                You should be able to grab the roof by a corner with the Move tool and snap it the corner of the garage below using the inference engine, or am I not understanding your question.
                If it has an overhang, snap to the corner as I suggested, then move the roof component the required distance along the x and y plane.
                • A
                  ALWX65
                  Dylan, thanks I will give that a try and let you know how it works out. There is no over hang just a rectangle the same size as the building below. I still have a lot to learn with the axis tool and inference engine thing.
                  ALW
