    'Snapping' to a face above a terrain?
    8 Posts 3 Posters 407 Views 3 Watching
    • leedeeteeL Offline
      leedeetee
      Just wondering the best way that I can draw on a face positioned directly 'above' a terrain model so that I can then drape the lines/faces onto the terrain below (using sandbox > terain.
      Every time I try drawing above, it always snaps to the terrain below!
      Can anyone help?!
        a little file example? (in V6 save as)
          leedeetee
          Attached is an example of what I am trying to do ....
          I use top view in Paralel projection and then draw my road/path, ready to be draped, but it always snaps to the terrain thus making it impossible to do!
          Thanks!
          Exampleproblem.skp
          • charly2008C Offline
            charly2008
            Hi, leedeetee,
            this happens only if you are in the X-ray mode.
            Karlheinz
              kill the Xray Mode
              Fill color the rectangle following taste / Edit Color, decrease the opacity 😉
              So you can see toward your surface 😎
              And draw your roads as you want ☀
                charly2008
                Hi Pilou,
                At this opportunity I had not thought of! But I must correct your reference. The path:
                Material -> Edit Color -> Create Material -> Opacity
                Karlheinz
                  leedeetee
                  Many thanks! So effective, so simple!
                    @Charly
                    You create new material if you need it 😄
                    In my case I just edit the current color painted then reput color opacity to 100% at the end of the process 😉
