    Mac Help Needed
    10 Posts 3 Posters 611 Views 3 Watching
    • M
      MartinRinehart
      I'm trying to write a bit of code that let's the developer access WebDialog's HTML files in locations of your own choice. I need to know what happens as you back up toward and at your root directory.
      If someone could try this:
      In the Ruby Console ask Dir::pwd (*nix for Print Working Directory). That should report something like /foo/bar/moo/baz. Then back up a directory with Dir::chdir( '..' ) and ask Dir::pwd again. (You can use the up arrow in the RC to save retyping.)
      It should report /foo/bar/moo. Done again you should get /foo/bar then /foo, then / and then? Do you get an error or do you just get / again? Or do you get an error before you get this far?
      Thanks ever so much!
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • T
        tfdesign
        Hi Martin, completely out of my depth here, but I am interested in code...
        all i get after typing
        Dir::pwd
        is;
        That's it!
        My book "Let's SketchUp!" Download from here
        • T
          tfdesign
          do I get a stroke, because the root directory is disabled by default on a Mac?
          http://support.apple.com/kb/HT1528
          • M
            MartinRinehart
            Dir::pwd
            is;
            That's it!
            And if you then Dir::chmod( '..' ) and then Dir::pwd do you still look at the single forward slash (root)?
            • T
              tfdesign
              Martin, yes.
              > Dir;;chmod( '..' )
              Error; #<NoMethodError; undefined method `chmod' for Dir;Class>
              (eval);16
              > Dir;;pwd
              • M
                MartinRinehart
                @tfdesign said:
                Martin, yes.
                > Dir;;chmod( '..' )
                > (eval);16
                > > Dir;;pwd
                Stupid me. That should be Dir::chdir( '..' ). Glad you showed the error message.
                • T
                  tfdesign
                  Martin,
                  I tried that, and the ruby console returned;
                  Nought. (or zero) πŸ˜„
                  • T
                    todd burch
                    The default working directory for Ruby inside Sketchup is root.
                    You could start with ENV['HOME'] to get to a more reasonable choice for user files.
                    • M
                      MartinRinehart
                      Thanks, guys.
                      I've looked harder and seen that there is NO Mac issue. It's a Windows-only problem.
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=26040&p=224362#p224362
                      I'll post my little movie later today and it just might run on Macs. (Crossing fingers, knocking wood, rubbing rabbit's foot.)
                      • T
                        tfdesign
                        That's heartening to hear! The amount of times I've heard windows developers moan that there is a fault, and it is Apple's fault! πŸ˜†
