    Face pointing towards the camera?
    25 Posts 7 Posters 1.7k Views 7 Watching
      MartinRinehart
      @adamb said:
      But thats much more work than a dot product. Your turning an orientation problem into something its not.
      I'm not seeing how a dot product solves the problem. Could you articulate or maybe Sketch something Up?
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        The result of the dot product can be used to determine if its the front or back side pointing towards the camera.
        t = ph.transformation_at(index) n = picked.normal.transform(t).normalize # global vector orientation c = Sketchup.active_model.active_view.camera.direction m = (c % n > 0) ? e.back_material : e.material
        If the dot product is positive then the backface is facing the camera, otherwise it's the front side.
          MartinRinehart
          Who is ph? Who is picked?
            ph is the PickHelper I used and picked is the face picked.
            It was taken from my test code.
            this is a more condensed sample:
            back_side = camera.direction % global_face_normal > 0
              tomasz
              @thomthom said:
              Any clues to how to determine that?
              Check my FrontFace.
              I just compare normals. The global transformation problem is solved by shooting a ray. That allows you to get an array of all parents of a face.
              • 2 / 2
