    Yet more questions on scale
    2 Posts 2 Posters 466 Views 2 Watching
    • C
      cimhtrad
      Now, this is rather newbie-ish but thats why i'm here πŸ˜„ πŸ˜„ .. I'm rather confused on the methods of transfering an image to an external program (for example,say, photoshop) while retaining a certain scale? For example , i've done a 3d building in sketchup, and i would like to transfer a 'parallel projection' view of the buildings front to photoshop to recolour. How would i transfer this image in 1:100 scale to photoshop, and then print from photoshop while retaining the correct scale?
      I know i could use Layout to attach the image according to scale, but Layout is rather sluggish for me. Is there a way to improve the speed at which layout inserts images from sketchup?
      Thanks a lot!
      • AnssiA
        Anssi
        You have some options:
        1. Print a PDF in 1:100 scale, and open that in Photoshop.
        2. A method I sometimes use:
        • set your background to pure white
        • draw a visible frame of known size around your model, so that nothing goes outside it. If you need a partial elevation, draw the frame as a hole in a large face, and place it in front of your model. If you need several views, make the frame a face-me component
        • zoom so that the frame almost fills the screen
        • export the view to a high-resolution image file
        • open the image in Photoshop
        • use the Trim command in Photoshop to crop away all white space around your frame lines.
        • use the Resize command to resize the image to the scaled size of the frame, and the desired resolution.
        • if the file needs further cropping, you can do that now.
        Anssi
