    Good morning
    3 Posts 3 Posters 344 Views 3 Watching
    • H
      horloge1957
      Hi all,
      I am new on this forum.
      I am a man 53 years old, living in France, in Paris.
      My hobby is clocks, watches, I try to be a watchmaker.
      So I need to make "handly" some pieces, materials. For this matter I need to learn Sketchup to draw and modelyse what I have to product.
      Best regards to you.
      Henri
      Bonjour,
      Ma passion est l'horlogerie. Je viens de passer un CAP à l'âge vénérable de 53 ans.
      J'ai besoin de concevoir des pièces et de les dessiner. Sketchup me semble un bon outil.
      Cependant je suis néophyte et butte sur des réalisation très simples. je connais Sketchup que depuis hier!
      Je compte sur vous et sur votre indulgence pour m'aider dans cette découverte. 💚
      Cordialement
      Henri
      • GaieusG
        Hi Henri and welcome!
        I have seen some really interesting and beautifully detailed clock (and watch) models made in SketchUp! It will be really interesting to see some nice examples from you, too, if you wish to share them.
        One tip already; a watch will obviously contain very tiny pieces. SketchUp has problems with creating faces that have edges at the scale around a millimetre so the general workaround is to model in a larger scale and only when finished, scale the model back to its normal size.
        Say it would be comfortable for you to model in millimetres at this scale. Instead, set your template to metres but work as usual - count the values as they were millimetres. This will result in a model scaled 1000:1 but in no time at the end you can easily scale it by 1/1000.
        (I also added you to the French usergroup so you can see and post in the French forum when you are logged in).
        • K
          KXI System
          Henri Salut et bienvenue!
          J'ai vu quelques très intéressante et admirablement détaillés horloge (et regarder) les modèles fabriqués dans SketchUp! Il sera vraiment intéressant de voir quelques beaux exemples de vous, aussi, si vous souhaitez les partager. Un bon truc d'ores et déjà, une montre sera évidemment contenir des morceaux minuscules. SketchUp a des problèmes avec la création de visages qui ont des bords à l'échelle autour d'un millimètre de manière générale la solution de contournement est de modèle dans une plus grande échelle, et seulement lorsque vous avez terminé, à l'échelle du modèle qui retrouve sa taille normale. Affirment qu'il serait commode pour vous de modèle dans millimètres à cette échelle. Au lieu de cela, réglez votre modèle en mètres mais le travail comme d'habitude - comptage des valeurs comme ils étaient millimètres. Cela se traduira par un modèle réduit 1000:1, mais en aucun temps à la fin vous pouvez facilement l'échelle de 1 / 1000. (Je vous ai également ajouté au groupe d'utilisateurs français afin que vous puissiez voir et d'écrire dans le forum français quand vous êtes connecté in).
          Blame the translator.
          Getting the perfect sig is hard...
          Google it!
