    [plugin] Ruby Code Editor - UPDATED to v3.0 3/4/2013
    56 Posts 11 Posters 42.1k Views 11 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Hi All,
      http://www.alexschreyer.net/blog/wp-content/uploads/2010/02/sketchup-ruby-editor-1-530x302.jpg
      EDIT (3/4/2013): This plugin has been updated to version 3.0. The plugin got a major update! Some of the new features are: better environment stability (editor, scrolling, results, etc.), code completion for SketchUp classes and methods and a variety of other minor updates.
      This code editor plugin offers an easy-to-use and visually appealing way to create and modify Ruby scripts directly within SketchUp. These scripts can then be used to create geometry, add functionality or add data within the SketchUp 3D modeling environment. The SketchUp Ruby API provides an extensive set of functions to automatize SketchUp in many ways or create scripted, computational geometry.
      I created this editor mainly for two reasons: One is that when I write code, I permanently need to look up documentation. To make this easier, I added a bunch of reference webpages to a browser in a tab. Also, a dropdown above the editor contains some common code snippets that can be inserted at the current cursor position. Version 3.0 also introduces a code-completion feature that you can invoke at any point by clicking CTRL-SHIFT. It contains SketchUp’s classes and methods.
      The other reason I wrote this as a plugin that works right inside of SketchUp is that I wanted it to give easy access to the Ruby coding environment and behave a bit more like a real code editor. To accomplish this, I added a bit of jQuery magic to make it look good and have some additional features. I also added the excellent CodeMirror 3.1 syntax highlighting engine. This provides the editor with multi-language code highlighting, correct TAB control, bracket matching and many more features. Just load the plugin and give it a try to see for yourself!
      The following video gives a brief overview of the current version:
      You can get this editor from my website (and see a changelog) at:
      http://www.alexschreyer.net/projects/sketchup-ruby-code-editor/
      For more on what you can do with it, check out my book "Architectural Design with SketchUp" (especially chapter 6):
      SketchUp for Design
      Tutorials and news about architectural design, 3D modeling, rendering, drawing, extensions/plugins, making, and scripting with Trimble's SketchUp and LayOut.
      SketchUp for Design (sketchupfordesign.com)
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
        remus
        😲 thank you! this is awesome!
          Looking very nice.
          got a couple of questions though:
          The Ruby Console reports no error - but does output the puts statements.
          • Chris FullmerC Offline
            Ooh I'm excited to test this out. i'm a huge believer in Jim's web console. The thought of anything to improve it make me giddy.
            Chris
            All my Plugins I've written
              @thomthom: The bottom of the page disappears when the window width gets so small that the file name breaks into the next row. I wanted to keep the layout fluid so that elements adjust on resize, but maybe I can find a better way to arrange the page more reliably.
              Not sure why there is no output. I didn't touch Jim's code that deals with capturing the Ruby response - does this also happen with the original Web Console?
              Cheers, Alex
                Jim
                A most excellent update Alex!
                  As far as the bottom output goes, I see it behaving exactly as Jim's does. What ever the script returns is output below. All puts statements get output in the Ruby Console.
                    So one thought, if its possible to clean this up I don't know - but the ruby console errors that get output are trying to display a lot of html markup now. A simple spelling error in model.selection returned this:
                    model = Sketchup.active_model
                    <br/>ent = model.active_entities
                    <br/>sel = modqerel.selection
                    <br/>
                    <br/>dist = 100
                    <br/>
                    <br/>sel.to_a.each do |e|
                    <br/>  if e.is_a? Sketchup;;Face
                    <br/>    e.pushpull dist
                    <br/>  end
                    <br/>
                    <br/>
                    <br/>end
                    "(eval);3;in&nbsp;&lsquo;initialize&rsquo;;&nbsp;undefined&nbsp;local&nbsp;variable&nbsp;or&nbsp;method&nbsp;&lsquo;modqerel&rsquo;&nbsp;for&nbsp;#&lt;RubyEditor;0x9912568>"
                    I added an image since I think it shows the error more clearly than the code block above.
                    I have no clue how that would be fixed.
                    Also, I am a little torn on the undo button. You set it so that it automatically wraps everything into a single undo command, which is nice so that a single press of "undo" will undo everything that was done in the script. But at the same time, I kind of don't like that because I'm worried I might forget to to write in my own start and commit operation methods. Don't know if that makes sense? I also don't know if I really would want it back how it was. Maybe this is a better workflow that I just need to adapt to.
                    Still though, I am liking it a lot!
                    Chris
                    • chrisglasierC Offline
                      chrisglasier
                      I know it is common for researchers to do their own thing but surely in this technically connected world we few should work together for the benefit of others.
                      A link and a pic ...
                      For my part I would like to incorporate these things into one interface.
                      Whatthink?
                      Chris
                      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                        Thanks for the feedback, everybody! Keep it coming...
                        @Chris Fullmer: Looking at the result capture code, it appears to convert characters such as the newline into HTML characters before sending it to the dialog. I tried to find a way around this - to no avail. Sending a newline \n to the execute_script doesn't work for me. Apparently that's why Jim put these conversions in there. I'll try later if there is an easier way to "encode" these before sending and "decode" them in Javascript in the dialog.
                        @chrisglasier: I remember your nameset approach from earlier. It can very well work with my editor. At some point, it would be great to have a code completion available, which could be your method. I am thinking of the user placing the caret, then clicking a key combination and then having a window pop up (like yours), where the method can be selected. How is your window implemented? I can easily incorporate something that resides in a DIV with Javascript.
                        Cheers,
                        Alex
                        • Dan RathbunD Offline
                          Dan Rathbun
                          @alexschreyer said:
                          I have also not tested this on a mac.
                          For the PC, put the following META tag in the HEAD section, so the browser displays Themed Controls instead of those old ugly plain Win 3.x style controls (ie buttons, scrollbars, etc.)
                          The Mac (Safari) should just ignore the tag.
                          HTML
                          	<!-- Use MS Common Controls ver 6+ if available -->
                          	<!--  (also known as XP style themed controls.)  -->
                          	<META HTTP-EQUIV="MSThemeCompatible" CONTENT="Yes">
                          _
                          I'm not here much anymore.
                            Dan Rathbun
                            I'd like to see the rb filename on the line below the toolbar (as a step towards future tabbed multi-snippet interface where the filename would be on the tabs anyway.)
                              Dan Rathbun
                              (No output?) The Ruby Console reports no error - but does output the puts statements.
                              @alexschreyer said:
                              @thomthom: Not sure why there is no output. I didn't touch Jim's code that deals with capturing the Ruby response - does this also happen with the original Web Console?
                              Yes it happens with the original WebConsole.
                              (1) Keep in mind that the output pane in the WebConsole (currently) displays the result of the eval method, NOT the output stream of STDERR and/or STDOUT as the SUConsole does. (This is why for multiple statements you see only the result from the LAST statement.)
                              (2) The puts method returns nil so you won't see anything if Jim's code stripped textstring "nil" out.
                                Dan Rathbun
                                Yes the HTML conversion may be necessary for the WebDialog side but not for the STDOUT.
                                Alex YOU caused the HTML tags to also go to STDOUT by inserting the line "p r" AFTER the conversion gsub! statements. IF "p r" is needed, move it up before the conversion statements.
                                  Dan Rathbun
                                  OK if a var evaluates to nil, and then you convert it to a String with .to_s, the result is an empty length String.
                                  So line 73 needs a nil test, thus:
                                  r!=nil ? r=r.to_s : r='nil'
                                  (Don't just have "r" as the boolean expression, because false values would get set to 'nil' instead of 'false'.)
                                    Thanks, Dan, for going through this so thoroughly. Everyone, please feel free to suggest code improvements. I would like to make this as useful as possible. Of course, I'll mention every help on the "About" tab.
                                    @Dan: I'll incorporate your revisions into the output code. That is really the part here that I had looked at the least.
                                    I like the idea of having tabbed multiple files. With the current tab support that should be relatively easy to implement.
                                    And thanks for the hint on the Windows UI look for IE. I didn't even know about the tag.
                                    Cheers,
                                    Alex
                                      Dan Rathbun
                                      I think I see another problem. If an error occurs don't you need to abort the operation instead of committing it?
                                      Try something like this:
                                        add_action_callback("exec") do |webconsole_dialog, p|
                                          v = webconsole_dialog.get_element_value('console').strip
                                          # puts v    # what's this for -- testing ??
                                          r = nil
                                          begin
                                            Sketchup.active_model.start_operation "RubyEditor"
                                            begin # evaluation
                                              r = eval v
                                            rescue => e
                                              r = e
                                              raise # pass to outer rescue clause
                                            end # eval
                                          rescue
                                            Sketchup.active_model.abort_operation
                                          else # only do if NO errors
                                            Sketchup.active_model.commit_operation
                                          ensure # always do this
                                            r!=nil ? r = r.to_s ; r='nil'
                                            p r
                                            r.gsub!(/ /, "&nbsp;")
                                            r.gsub!(/\n/, "<br>")
                                            r.gsub!(/'/, "&rsquo;")
                                            r.gsub!(/`/, "&lsquo;")
                                            r.gsub!(/</, "&lt;")
                                            webconsole_dialog.execute_script("document.getElementById('results').innerHTML='#{r}'")
                                        end # callback
                                        Dan Rathbun
                                        Alex.. you did not change the Name of the DefaultSettings Key ('WebCon'), so your plugin is overwriting the values for Jim's standard WebConsole in the registry.
                                        There is always the possibilty that some people may still wish to use Jim's "plain Jane" version from time to time, even with yours installed.
                                        You should setup a unique Keyname for your defaults.
                                          I'll change the dialog name. Must have overlooked that one. I changed the class name.
                                          In the meantime, I figured out how to get linebreaks from a file into a dialog.
                                          filename = UI.openpanel
                                          f = File.new(filename,"r")
                                          text = f.readlines.join.gsub!(/\n/, '<KghBr31sD>')
                                          ndlg = UI;;WebDialog.new("Ruby Web Console", true, "WebCon123", 600, 400, 100, 100, true)
                                          ndlg.set_html ("<html><head></head><body><textarea style='width;100%;height;100%' name='mybox' id='mybox'></textarea></body></html>")
                                          ndlg.show {
                                            ndlg.execute_script("var text = '#{text}';var asddsa = text.replace(/<KghBr31sD>/g,String.fromCharCode(13));document.getElementById('mybox').value = asddsa")
                                          I think I saw the method (i.e. using a gibberish tag) discussed recently in the developers forum. I'll give that a try soon.
                                          Cheers,
                                          Alex
                                            chrisglasier
                                            @alexschreyer said:
                                            @chrisglasier: ... It can very well work with my editor.
                                            It is not your editor it belongs to Jim; what you did, as I did, was to dress it up. But I don't want to focus on individual efforts but more on why the cognoscenti allow software companies to fob us off with metaphors for paperwork rather than providing digital machines.
                                            Take for example your original cheat sheets and my/Jim's Sketchup API digital device which provided an opportunity to link up many other devices like the console. The style is not an issue and you are more adept at implementing the links than an amateur and reluctant coder like me; the code is freely available here.
                                            I am very disappointed that you ignored this opportunity to exploit a way to link up data (that belongs to objects that have names) and digital devices (that can automate common tasks).
                                            • 1 / 3
