How to "build" with bricks in sketchup - Newbie
How about getting hold of one of Dome's segments and "cut" it up into bricks?
If you don't want absolute precision just aspect
(briks will be not separated objects)
Call hidden Geometry
Select faces you want and Apply Joint Push Pull by Fredo6
Duhhh is the only response that seem appropriate. I should have been able to figure that out.
Well, thanks though. On to the next phase.
I am sure i won't have anymore questions as it is all super clear to me now ;>)
@jagizzi said:
...I am sure i won't have anymore questions as it is all super clear to me now ;>)
You never know...
@jagizzi said:
Gaieus,
I am on my Mac, which is new to me, so I don't know how to capture a window to post so I will have to save the sketchup file itself. (Would take that bit of knowledge too, if you knew how). Easy on my PC buy am learning the mac as i go.
Thanks,
jagizzi to do a screen capture on your mac you can use "command/shift/3" for a full screen capture, or "command/shift/4 " will bring up a set of gun sights to capture the area you highlight.
I have always wanted to build one of these ovens for bread and pizza, so I will follow this closely.
