    Creating Hole Patterns
    7 Posts 6 Posters 3.1k Views 6 Watching
    • A
      ameliab
      Does SU have any hole pattern functions? I can't seem to find one. I have a line of 120 holes on 1" centers, and I don't want to have to make 120 copies of the circle. This is a simple function in Solidworks, so I assume SU must have something similar.
      amelia
      • K
        KXI System
        I think your're asking how to make a repeated copy, follow these simple steps:
        Getting the perfect sig is hard...
        Google it!
        • D
          dedmin
          amelia
          Must have??? Free software against 10 000$ Gorilla! And it is simple to apply but under the hood is a lot more! You can select the hole and copy it just like any other object in SU - as was mentioned above. And using rotate while holding CTRL You can make radial array
            Or like this πŸ˜‰
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              See attached file for ideas.
              Sorry for the size, I could have used les segments for my circles.
              Array of holes.skp
              • M
                muchado
                @dedmin said:
                amelia
                Can one do this in a dynamic component? I wanted to created a "troughed slab" (also known as a "ribbed slab") by repeating a depression across a cuboid, but SU does not make the cut in the surface for the copies.
                Using SU DC's to model repeated depressions in a slab
                • M
                  muchado
                  Sorry, it appears that this has been answered before:
                  http://forums.sketchucation.com/viewtopic.php?f=289&t=23096
                  http://forums.sketchucation.com/viewtopic.php?f=289&t=21449
                  http://forums.sketchucation.com/viewtopic.php?f=289&t=18651
                  http://forums.sketchucation.com/viewtopic.php?f=289&t=17054
                  The problem appears to be that SU does not do this. However there appear to be at least one work-around that involves creating the positive volumes and then hiding the lines of the joins. I had thought about joining pieces together, but thought that I would be stuck with the edges, but using the trick of "hiding" the edges solves the problem.
