    Multi-Surface Extrude Plug in?
    6 Posts 5 Posters 1.7k Views 5 Watching
      brettwdavis
      Does anyone know if there is a plug-in that will extrude multiple surfaces at the same time? They can all be the same extrusion height in the same direction. I have hundreds of surfaces that need to be made into 3D. Thank you.
        404 Not Found
        (forums.sketchucation.com)
        • K Offline
          kostas_designer
          Push-pull multiple faces along normals / vector / randomly (can't remember where that is, i think at
          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm )
          OR multiple_push_pull:
          http://www.cad-addict.com/2009/09/sketchup-plugins-extrude-multiple-faces.html
            It was inside old Projection plug by Didier Bur
            New Projection has not the randomly
            Another randmly or not is Protrude by Jim Foltz
            Greeble by Chris Fullmer
            All very fun plugs! 😎
            • Chris FullmerC Offline
              Are you by chance making buildings? I might have another script that would help be able to control the height of each floor, the ground floor can be controlled separately than the upper floors, and you can control how many floors to add, etc. Its a planners tool I wrote for myself that I keep meaning to publish.
              Chris
              All my Plugins I've written
                brettwdavis
                Chris,
                I'd love to take a look at that plugin if you get a chance. I am looking to build a simple urban context from a 2d CAD plan. Just looking for a quick way to make generic boxes around our architectural model. Please let me know if you post it. I really enjoy your other plugins, keep up the good work. Thanks!
