    Control Points causing SU 7 to crash
    4 Posts 4 Posters 1.4k Views 4 Watching
      aswiger
      I am using the Control Points plugin, and there seems to be at least a couple issues when following along in some of the youtube videos posted by the plugin's creator. First, whenever I add control points then use the move tool to move one of the points, SU will give me an odd error message: "most probably geometry group was erased", then crash.
      Also, when I draw to circles and select both, the blend option is not visible on a right click. I've restarted my machine, re-installed the plugin, tried using both 1.6 and 1.7 to no avail. I'm using SU 7.1 pro on Windows 7. Any advice? Thanks!
      Aaron
        malakon
        The same is happening to me
          You're more likely to get attention from the plugin developer is you post in the thread for the plugin.
          • V Offline
            Vicspa
            Same here, tried many times, and SU crashes on me
