    [Plugin] FredoTools::RevertCurve 1.1a - 25 Aug 11
    4 Posts 4 Posters 27.1k Views 4 Watching
    • fredo6F
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      RevertCurve is a small standalone plugin that reverses the orientation of a curve.
      Note: The script runs fine for standalone curves (free edges with no bordering faces). If not the case, the script needs to delete the curve edges and reconstruct the curve and bordering faces, with their material. Not a big deal, but be careful when the curve borders a fully textured set of faces.
      Normally, most scripts dealing with curves should manage the orientation of curves, either being independent of the orientation, or proposing to use the reverse direction. So the script may be useful in other cases only.
      http://forums.sketchucation.com/download/file.php?id=49286
      No User manual currently.
      • Sketchup versions: 6 and above (Free and Pro)
      • Language: English, French
      • Menus: by default, it is installed in Tools > FredoTools > Revert Curve
      • Icon toolbar: Fredo6 Tools - Optional icon, not shown by default
      http://forums.sketchucation.com/download/file.php?id=49285
      RevertCurve is now installed as part of FredoTools.
      See the main post for this plugin for Installation
      http://forums.sketchucation.com/download/file.php?id=49284
      No video for the time being
      http://forums.sketchucation.com/download/file.php?id=49288
      • Select one or several curves (or a part of the model containing curves)
      • Invoke the Plugin (menu or icon) and the curves will be inversed
      • Also available in the Contextual menu Revert Curve
      http://forums.sketchucation.com/download/file.php?id=49289
      RevertCurve 1.1a – 25 Aug 11: Now part of FredoTools. No functional change however
      RevertCurve 1.0a – 06 May 10: Initial Release
        Reversing ☀ renversant 😉
        • JClementsJ
          JClements
          Thanks, Fredo
          • M
            mmyoung
            Ahhh. Thank you!
            In parametric applications I am accustomed to detecting and altering vector direction.
            How do you detect curve direction in SkUp?? I didn't even know it mattered until yesterday!
            Anyway -- many many thanks for posting this little gem.
            Michael Young
            Albuquerque
            OSX; SketchUp, Vectorworks, and Wings3D
            (which play nicely together)
