    ..."Night Scene"...Updated
    21 Posts 16 Posters 3.0k Views 16 Watching
      teofas
      This is my first night scene render, hope you like it, your c&c are most welcome! Design is not mine, its from a magazine...
      software: sketchup+vray4skp+psCS3
      Heres the updated...feel free to comment
      http://img710.imageshack.us/img710/9789/nightext4final.jpg
      Heres with my sketchup style...
      http://img59.imageshack.us/img59/3739/teofassketchupstyle.jpg
      http://www.spazioarquitectura.com
        It is not so bad πŸ˜‰ πŸ‘
        What is the name of the renderer?
        • tridemT Offline
          tridem
          Hi teofas, for me it's a masterpiece, good materials, good lighting, good environment. πŸ‘
          If I had to suggest an improvement, maybe you could straighten the camera in order to adjust the vertical lines, expecially near the edge of the picture (eg the left column) they annoy a bit.
          Cheers, Luca
            ScottPara
            Excellent work.
            Scott
            Love the fact that some HATE my avatar.....
            • DanielD Offline
              Daniel
              Your work is always outstanding. Thanks for sharing it.
              My avatar is an anachronism.
              • 3 Offline
                3dbuilder
                This is an excellent first pass at this scene, I think. Particularly well-done is the chandelier scene upper left. You might reduce the glow of that light somewhat to achieve a more subtle variation of light in that room.
                If this shot suffers from anything it might be a lack of a central focus. Everything is lit so evenly across the entirety of the scene that the eyes are pulled everywhere across the scene. Sometimes this is done on purpose; but many times it is better to think of your photograph as telling a story and every story has a central theme to it.
                Pick a focal point of each scene and then light everything to push the viewers eye to that focal point.
                The pool is lit well, but suffers from lack of obvious geometry to support the light. You might throw in some geometry representing the light sources throwing those rays to increase believeability.
                The track lights and sconces are very well done. I would tone down the tube lighting falling down the rock wall just to create some better ambience and this will tend to help focus your scene on the room central to the photograph.
                There is also a distracting light source in the window to the left of the pool area that is pulling the eye needlessly away from your central focus. I'd tone down that strength.
                The lighting in the main room is generally well-done for a first pass, but two things stand out to me:
                1. The reflection of light on the left wall (where the orange art hanging is) seems much too strong given the obvious light sources in the room. This is also true of the back wall. Tone those area lights down a bit. You want to try to avoid large areas of 100% white as this makes the scene look washed out.
                Finally, the "globe" lamps in the main room over the chairs have holes in the bottoms of them. I think you should maybe put a spot light inside each of those lamps so that a halo of light appears on the floor. Most of the light photons that escape those lamps downward are going to strike the floor under and around the chairs.
                Nicely done. I'd love to see your second pass to get a flavor for how subtle changes can affect the overall scene.
                Cheers,
                • EarthMoverE Offline
                  EarthMover
                  Great work bro!!! Love, love the lighting. Building does appear to be leaning to the right though.
                  Content Creator at Skapeup
                  • stefanqS Offline
                    stefanq
                    Good work Teo! It's not so easy like a day time render, huh?
                    Congrats!
                      steelers05
                      definitely a great start...i think overall though the scene is too dark. You lose a lot of the detail. Maybe add a subtle HDRI for some environment lighting. I also agree about the verticles of the building. Minor things though to a great start. Anxious to see an update.
                      • ken28875K Offline
                        ken28875
                        Hi teofas,
                        Really nice work as always coming from you. But the render will even look better if you follow some good advice from 3dbuilder. I do agree that having less lights or some lights less bright will allow the viewer to direct their attention to one main focus (in this case seems like the center of you living room). The wall on the right should be less lighted. It's kind of attracts my eyes to it right now.
                        Anyway, keep up the great work and looking forward to more of you night scenes.
                        Best,
                        _KN
                        Follow Your Dreams.
                        • ken28875K Offline
                          ken28875
                          Hey Pilou,
                          I believe teofas is using Vray for Sketchup.
                          Follow Your Dreams.
                            teofas
                            thx so much for all your comments, really helps, cause this is like i said my first exterior night scene,,,right now im working on the update..ill post it in few hours!, thx to all!
                              sepo
                              Good start Teo. I think lights should be more yellow and sky more blue.
                              • 7 Offline
                                7kashmir
                                vaya vaya vaya ... muy bonito ... muy bonito ... jejeje saludos amigo!! como siempre excelente ...
                                  teofas
                                  Thx kash and sepo...i post and update.
                                  • holmes1977H Offline
                                    holmes1977
                                    Hi Teo
                                    Fantastic renders. I always look forward to your new posts.
                                    I would have to agree with seop and the sky. I think it need to be slightly lighter.
                                    Just checked out your web site. Amazing collection of renders. Inspiration 😎
                                    Exaggeration makes a dull story better.
                                      dirkkkk
                                      Just amazing work their... Love the scene.. the lights are great... I suppose you use Xfrog?
                                      Best
                                      From Holland
                                        teofas
                                        holmes: thx bro, glad you like the webpage, still need some improvements..kinda wip
                                        Dirk: thx bro, the trees are from warehouse, look for the smartrees from andeciuala,,
                                          cmoreink
                                          Looks good, I'll examine further once my hangover goes away πŸ˜•
                                          my portfolio
                                          • E Offline
                                            EDMON242004
                                            This is a really realistic night scene IMO, I am currently working on a night scene myself but I don't know where to start, could be a great help if you could direct me, a basic tutorial maybe? thanks, by the way I use vray for su. thanks and great render
                                            • 1 / 2
