    How big is too big?
    8 Posts 5 Posters 671 Views 5 Watching
    • 3 Offline
      3dbuilder
      How big is too big?
      What are the practical limits to the number of faces in a drawing (assuming say ... 2gb RAM with an nVidia 9500 mid-range 512mb graphics card)?
      Is faces the biggest determinate of performance?
      How large/complex can a model get before it gets unworkable?
        Edges and faces - i.e. geometry - will mainly affect your CPU. the higher clock speed it has (per core - as SU cannot handle multiple cores) the better.
        The graphics card will chime in when displaying shading, shadows, materials and such. If that cannot "help" the CPU (because no OpenGL compatible), this task needs to be done by the processor, too. This of course leads to worse performance.
        Now I had a computer with a 2.77 GHz (single core) processor, 512 Mb ❗ RAM and a 128 Mb Ati Radeon X550 card (I could not see any performance boost when HW acceleration was on).
        With this, I built amodel of 12+ million edges and 300K+ faces but of course, I used hidden layers a lot. There were no heavy materials however as it was rendered outside of SU and would be re-textured anyway. But I had no special problems with that model.
        True that I can spin it around easily with my current rig.
        πŸ˜‰
        • 3 Offline
          3dbuilder
          With this, I built a model of 12+ million edges and 300K+ faces but of course, I used hidden layers a lot.
          Gaieus ... thanks a lot for the benefit of your experience.
          I have a Intel Core 2 Quad running at 2.83 Ghz with a (probably underpowered a little bit) nVidia 9500 512mb GPU.
          My model has about 800,000 faces.
          I am facing many performance issues (even with layering effectively).
          Is this the experience I can expect with a model this complex?
          I am taking steps to reduce model complexity and so hoping for an improvement.
          Any advise would be much appreciated.
          Cheers.
            Well, I saw you commented in the "purge topic".
            So also purge regularly (although what is not in the model window, should not significantly decrease performance maybe only when autosaving for long seconds or even minutes).
            And there are very nifty plugins nowadays. If you use components extensively and smartly to keep your file size down, you may have noticed that just keeping file size down won't affect performance when high poly components are orbiting on the screen. But here is Fredo's "GhostComp" plugin with which you can keep a low poly version (or even just a symbol) on screen, navigate and work easily and only turn on real components when rendering/exporting something.
              Ray Bruman
              This topic is crucially interesting to me right now.
              Elsewhere in this Newbies forum I have described a problem
              "Type faces for Maps" with one of my very first SketchUp models.
              It is really just a 2D drawing, a street map of about 1.5 square
              miles with lots of tiny alleys, hence lots of small text.
              The size of the SKP file swelled to about 30 MB, which a
              friend called "titanic" compared to other models. I have no
              way of knowing; I'm a newbie.
              Other numbers, from the "Model Statistics" panel, show that
              it has, at one of the recent revisions of the drawing:
              Edges: 344768
              Faces: 120967
              Component Instances: 783
              Component Definitions: 399
              Layers: 9
              Styles: 1
              ... and all other stats are 0.
              It uses no colors but black, and has no textures
              or other bitmaps -- just edges and text, in only
              two fonts (Arial Narrow and Century).
              So my model looks quite modest compared to the one Gaieus
              described. I tried to Purge it, and reduced it only about 1 MB
              or about 3%.
              Still, 30 MB is much larger than some e-mail attachment limits.
              And I have to wait for it often while it loads on my little
              MacBook.
              Is this file small, medium, large, titanic... or what?
              Thanks to all.
              I have an address at Mac dot Com with the name Raybees and
              I would like to meet users of SketchUp and/or Inkscape near
              Berkeley, CA USA.
                That model of mine was only about 6-7 Mb. I believe that those many 3D text groups that you inserted make it so big. The only solution for that could be to insert a character of each letter into the model, make it a component and use those component definitions to put your text together. But I certainly know this would be so tedious that you rather wait while SU is lagging.
                But you could definitely put all those 3D texts on a separate layer and hide it while working with the model.
                • AnssiA Offline
                  Anssi
                  In an earlier thread it was also noted that while using components has the effect of reducing file size on disk, they tend to have a negative effect on performance when the model is open. This happens if the model is deeply "nested", that is, has many components that have subcomponents inside that have subcomponents etc. A typical example is a 3D Tree component that may consist of many branch components, that have sub-branch components that have leaf components. If everything inside is exploded, the file size becomes larger, but the computing effort required from SU becomes smaller, while the actual polycount remains the same.
                  Anssi
                  • Jean LemireJ Offline
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas.
                    Tricks for working with large files.skp
                    Use the Scenes tab on top of the model window.
