    [Plugin] Manifold v2.2
    126 Posts 19 Posters 68.3k Views 19 Watching
      It works on a copy of the original group that it has made and offset to one side.
      The third 'error group' [if any] simply highlights these errors and it is overlaid onto the original group...
      However... please note that this particular 'Manifold' tool is a slow old crock and it has long been superseded by some newer better things... so I no longer 'support it'...
      Thomthom's 'SolidInspector' shows where errors occur that are causing non-solidity.
      My newer 'SolidSolver' tries to fix them [affecting the original, but 'undo-able'].
      There are also one or two other tools that try to do this kind of thing too...
      I recommend you get those and retry.
        tarzip86
        Works brilliantly for my purposes. Cheers!
        • W Offline
          WorldWiz
          While this plugin is running, does it get interrupted if my computer goes into standby mode?
            I really don't know. 😕
            BUT there are now several better tools like SolidSolver and SolidInspector anyway 😒
              ladyquestio
              Using version 8 free BTW
              I have been trying to make use of this plugin. But it does not seem to work . I am getting an error message when i look in console
              here is a copy of the messages i get .
              manifold
              Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:199:in add_group' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:199:in copy_group'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:142:in activate' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:1039:in select_tool'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:1039:in `manifold'
              (eval):42
              #Sketchup::Model:0xcf41cb0
              Can you look and tell me where the error is ?
              scanner1x.skp
                This is a very old Plugin.
                It has issues with all current versions, and v8 which is no longer supported...
                I suggest you try my SolidSolver or thomthom's SolidInspector² ?
                • 6
                • 7
                • 7 / 7
