    Four point plane to Point+Vector Plane?
    10 Posts 3 Posters 1.0k Views 3 Watching
      http://code.google.com/apis/sketchup/docs/ourdoc/geom.html#introduction
      A plane can be represented as either an Array of a point and a vector, or as an Array of 4 numbers that give the coefficients of a plane equation.
      How does one convert a plane defined by four points to a plane defined by [ point3d, vector3d ] ?
      "coefficients of a plane equation" ❓
        remus
        Just a small correction, when you say "a plane defined by 4 points" you really mean a plane defined by 4 numbers (which are the coefficients of the equation of the plane.)
          hmm... 😳 always read "numbers" as "Point3d"s...
          I never used or encountered anything other than the [ point3d, vector3d ] variant, but I want to make a method to ensure that's the format I get planes in.
            http://local.wasp.uwa.edu.au/~pbourke/geometry/planeeq/
            The standard equation of a plane in 3 space is Ax + By + Cz + D = 0
            The normal to the plane is the vector (A,B,C).
            So given a plane of [a,b,c,d], the normal would be Geom::Vector3d.new(a,b,c)?
            But what is d ? And I don't see where I derive any point3d from this - to fit [ point3d, vector3d ] ...
              Think it makes sense now....
              Did some testing:
              p1 = [200,200,200]
              [200, 200, 200]
              p2 = [400,200,200]
              [400, 200, 200]
              p3 = [400,400,200]
              [400, 400, 200]
              p4 = [200,400,200]
              [200, 400, 200]
              Geom.fit_plane_to_points(p1,p2,p3,p4)
              [-0.0, -0.0, 1.0, -200.0]
                remus
                d is just a constant, so unless theres an error in the docs (i.e. they mean 'you can define a plane with a vector and a constant', not unlikely) then youll have to find a point on the plane.
                  This seem to work.
                  	# Return a plane in the format [ point3d, vector3d ]
                  	def self.normalize_plane(plane)
                  		return plane if plane.length == 2
                  		a, b, c, d = plane
                  		v = Geom;;Vector3d.new(a,b,c)
                  		p = ORIGIN.offset(v.reverse, d)
                  		return [p, v]
                  When I test it:
                  p1 = [200,200,200]
                  [200, 200, 200]
                  p2 = [400,200,200]
                  [400, 200, 200]
                  p3 = [400,400,200]
                  [400, 400, 200]
                  p4 = [200,400,200]
                  [200, 400, 200]
                  plane = Geom.fit_plane_to_points(p1,p2,p3,p4)
                  TT_Lib;;Geom3D.normalize_plane(plane)
                  [Point3d(0, 0, 200), Vector3d(0, 0, 1)]
                  • AdamBA Offline
                    AdamB
                    Its just not efficient. A plane is commonly defined by a direction and a distance along that direction (the "D" constant). Keep in mind a plane is infinite so you just need "a point" - any point on the plane to define it.
                    So explicitly storing the Point3d is (groan) pointless. If you want a point on the plane from its plane equation you just do:
                    plane_normal.scale(D)
                    ie You just need to store 4 values not 6 as you are doing.
                    • AdamBA Offline
                      AdamB
                      Also you really don't want 4 points as input as they may not be coplanar. 3 points are guaranteed to be coplanar.
                        Yea - I'm not dealing with points. As remus pointed out to me, it was four numbers. I just wanted a method that'd convert a plane defined as four numbers into [ point3d, vector3d ] - as the Geom module says planes can be in either format.
